Extend and Distribute a VGA Signal to a Remote Display over Cat5 Cabling (Receiver Only). The STUTPRXLGB VGA Video Extender Remote Receiver over Cat 5 (UTPE Series) can be installed with the StarTech.com 4 port, 8 port or wall-plate VGA over Cat 5 extenders (ST124UTPE / ST128UTPE), enabling remote monitors to be connected up to 300m (950ft) away from the source.
Supporting a maximum resolution of 1900x1200 (resolution varies by distance), this VGA over Cat 5 receiver unit provides crystal clear video content to your remote display. Plus, for ease of installation the STUTPRXL includes the mounting bracket for versatile mounting options.
- StarTech.com VGA over Cat 5 Extender Remote Receiver (UTPE Series) - video extender
- Video extender
- Form Factor
- External
- Localisation
- United Kingdom
- Max Transfer Distance
- 300 m
- Power
- DC 12 V
- 476 g
- Video extender
- Form Factor
- External
- Black
- Localisation
- United Kingdom
- Connectivity Technology
- Wired
- Max Resolution
- 1900 x 1200
- 300 m
- 1 x VGA - HD-15 female , 1 x network - RJ-45 female
- Mounting Kit
- Included
- FCC, RoHS
- Power Device
- External power adapter
- Voltage Required
- DC 12 V
- 476 g
StarTech.com 6 ft Coax High Resolution Monitor VGA Video Cable - HD15 to HD15 M/M | In Stock | £5.74 |
StarTech.com 6 ft Coax High Resolution VGA Monitor Extension Cable - HD15 M/F | In Stock | £5.74 |
StarTech.com 50 ft Cat5e Blue Molded RJ45 UTP Cat 5e Patch Cable | In Stock | £11.71 |
StarTech.com 100 ft Cat5e Blue Molded RJ45 UTP Cat 5e Patch Cable | In Stock | £21.76 |
StarTech.com 15 ft Coax VGA Monitor Extension Cable - HD15 M/F | In Stock | £11.78 |
StarTech.com 75 ft Cat5e Blue Molded RJ45 UTP Cat 5e Patch Cable | In Stock | £13.35 |
