StarTech.com VGA HD15 Slimline Gender Changer - M/M
Quicklinx: 3ZKMWS00 Mfr#: GC15HSM
£5.03 ex VAT
£6.03 inc VAT
Convert an HD15 female connector into an HD15 male connector. This Slimline Gender Changer (HDDB15M to HDDB15M) converts a High Density DB15 female connector to a High Density DB15 Male connector, allowing you to connect devices with a female HDDB15 output to a device with a HDDB15 female input.
StarTech.com VGA Gender Changer - HD15 Female to HD15 Male - - Male/Male - Monitor Adapter (GC15HSM) - VGA cable
VGA cable
Connector
HD-15 (VGA) - male
Connector (Second End)
HD-15 (VGA) - male
StarTech.com 2 Port Steel USB KVM Switch with Audio and USB 2.0 Hub, 2 Port VGA Dual Monitor KVM Switch with PS/2, 4 Port Steel USB KVM Switch with Audio and USB 2.0 Hub
VGA cable
Connector
