StarTech.com Vertical Dual Monitor Stand
Quicklinx: F2K3WS00 Mfr#: ARMDUOVS
£89.35 ex VAT
£107.22 inc VAT
This vertical dual-monitor stand, with its sleek aluminum design, raises two displays off the surface of your desk or table, to save space while increasing your productivity. With its robust construction, the freestanding dual-monitor mount securely holds two VESA mount monitors, each up to 27", stacked vertically.
The dual-monitor mount holds two displays, one above the other. You can adjust the height of the monitors along the 28" (710 mm) pole, to work in comfort with your two-monitor setup.
The adjustable monitor stand for desks enables smooth, effortless +15/-15 degree tilt and swivel, making it easy to find the perfect viewing angle. It can also rotate a full 360 degrees, giving you the flexibility of portrait or landscape viewing.
The dual-monitor stand securely holds your monitors in place while complimenting your office decor with its black and silver aluminum design. The monitor stand supports two monitors, each up to 27" (686 mm) in size and 17.6 lb. (8 kg) in weight.
The VESA monitor stand is easy to install, featuring quick monitor attachment and removal. It also provides cable management to keep your cables neatly out of sight.
StarTech.com Vertical Dual Monitor Stand for up to 27" Monitors - Aluminum - stand
Stand - desktop stand
11.5 cm x 16 cm x 94 cm
Tilt
-15° to 15°
Rotation
360°
Swivel
-15° to 15°
Adjustments
Height, tilt, swivel, rotation
4.2 kg
Recommended Use
2 monitors
Recommended Display Size
13"-27"
VESA Mounting Interface
100 x 100 mm, 75 x 75 mm
Max Load Weight
8 kg
Material
Plastic, aluminium
Black, silver
Package Content
2 x VESA monitor mounts, 8 x M4x30 screws, hex key (4mm), hex key (3mm), 8 x washers, 16 x spacers, lower pole, base, 8 x M4x14 screws, 8 x M5x14 screws, upper pole, pole connector, 2 x cable management hooks, 3 mm hex key with screwdriver tip, 2 x cable management hook screws, 8 x M5x30 screws
11.5 cm
16 cm
94 cm
4.2 kg
Material
Plastic, aluminium
Black, silver
Package Content
AV Furniture
Stand
Recommended Use
2 monitors
Placing / Mounting
Desktop stand
Cable Management
Integrated cable management
13"-27"
Tilt
-15° to 15°
Rotation
360°
Swivel
-15° to 15°
Adjustments
Max Load Weight
8 kg
Dimensions & Weight Details
4.8 kg
StarTech.com Vertical Dual Monitor Stand Bundle deal on StarTech.com Vertical Dual Monitor Stand
£189.11
Price Range Ex VAT: 50 - 100
