StarTech.com Vented 1U Rack Shelf - 7in
Quicklinx: CWS9WS00 Mfr#: CABSHELF1U7V
Product Type: Rack shelf, Rack shelf
22 in stock
£17.43 ex VAT
£20.91 inc VAT
This 1U rack shelf lets you add 7 in. of flat storage space to any EIA-310 compliant server rack or cabinet. The shelf is vented to improve air flow and help lower temperatures in your rack.
The durable fixed-rack shelf can hold up to 20 kg (44 lbs.) of equipment and is constructed using SPCC commercial-grade cold-rolled steel.
The 1U cantilever shelf lets you optimize your working space by giving you the ability to mount equipment to your rack instead of taking up desk or floor space. It's perfect for your SOHO (small office, home office) environment, server room or any other location with limited space available.
You can install the 1U vented rack shelf in your rack at any height, giving you a stable surface for placing equipment that's un-mountable or storing your tools.
StarTech.com 1U Vented Server Rack Mount Shelf - 7in Deep Steel Universal Cantilever Tray for 19" AV & Network Equipment Rack - 44lbs (CABSHELF1U7V) rack shelf - 1U
Rack shelf
Package Content
4 cage nuts, 4 mounting screws
Rack Size
7"
Height (Rack Units)
1U
Product Material
Cold-rolled steel
48.26 cm x 17.78 cm x 4.45 cm
Vented, cantilever
Rack shelf
Product Material
Cold-rolled steel
Package Content
Rack Size
7"
Height (Rack Units)
1U
48.26 cm
17.78 cm
4.45 cm
Weight Limit
20 kg
Mounting Kit
Included
Vented, cantilever
Limited warranty - lifetime
CWS9 StarTech.com Black Standard Universal Server Rack Cabinet Shelf In Stock £26.81
CWS9 StarTech.com 1U Adjustable Mounting Depth Rack Mount Shelf - Heavy Duty Shelf - 175lbs / 80kg In Stock £62.63
CWS9 StarTech.com 1U Adjustable Mounting Depth Vented Rack Mount Shelf - Heavy Duty - 250lbs / 113kg In Stock £81.39
CWS9 StarTech.com 2U 22in Depth Fixed Rack Mount Shelf - 50lbs / 22kg In Stock £35.56
CWS9 StarTech.com 2U Rack Mount Cantilever Shelf - Heavy Duty Fixed Server Rack Shelf - 125lbs / 56kg In Stock £44.04
CWS9 StarTech.com Vented 1U Rack Shelf - 7in In Stock £17.43
CWS9 StarTech.com 1U Rack Shelf - 10in In Stock £18.91
Price Range Ex VAT: 0 - 50
