This 1U rack shelf lets you add 10 in. of flat storage space to any EIA-310 compliant server rack or cabinet. The shelf is vented to improve air flow and help lower temperatures in your rack.
The durable fixed-rack shelf can hold up to 20 kg (44 lbs.) of equipment and is constructed using SPCC commercial-grade cold-rolled steel.
The 1U cantilever shelf lets you optimize your working space by giving you the ability to mount equipment to your rack instead of taking up desk or floor space. It's perfect for your SOHO (small office, home office) environment, server room or any other location with limited space available.
You can install the 1U vented rack shelf in your rack at any height, giving you a stable surface for placing equipment that's un-mountable or storing your tools.
- StarTech.com 1U Vented Server Rack Cabinet Shelf, 10in Deep Fixed Cantilever Tray, Rackmount Shelf for 19" AV/Data/Network Equipment Enclosure with Cage Nuts & Screws, 44lbs Weight Cap. - 1U Network Rack Shelf (CABSHELFV1U) - rack shelf - 1U
- Product Type
- Rack shelf
- Package Content
- 4 cage nuts, 4 mounting screws
- Black
- Rack Size
- 10"
- Height (Rack Units)
- 1U
- Product Material
- Cold-rolled steel
- 48.26 cm x 25.4 cm x 4.45 cm
- Vented, cantilever
- Product Type
- Rack shelf
- Product Material
- Cold-rolled steel
- Package Content
- Rack Size
- 10"
- 1U
- 48.26 cm
- 25.4 cm
- 4.45 cm
- Black
- Weight Limit
- 20 kg
- Mounting Kit
- Included
StarTech.com 50 Pkg M5 Cage Nuts for Server Rack Cabinets | In Stock | £13.28 |
StarTech.com 50 Pkg M6 Mounting Screws and Cage Nuts for Server Rack Cabinet | In Stock | £33.54 |
StarTech.com Black Standard Universal Server Rack Cabinet Shelf | In Stock | £33.34 |
StarTech.com 1U Rack Shelf - 10in | In Stock | £22.66 |
StarTech.com Vented 1U Rack Shelf - 16 in. | In Stock | £35.80 |
