StarTech.com VDSL2 Ethernet Extender Kit
Quicklinx: B9GHWS00 Mfr#: 110VDSLEX2GB
Scale your 10/100 Mbps Ethernet network up to 1.5km over RJ11 phone lines. The StarTech.com VDSL2 Ethernet extender kit lets you connect a remote network segment or device to your network, using RJ11 phone cable.
The network extender is a simple, reliable, and cost-effective solution for spanning your network across long distances. While maintaining high speeds, the extender also safeguards your investments by providing surge and ESD protection to your connected device.
The VDSL2 extender reduces the hassle of networking your devices or workstations by overcoming the 330ft (100m) distance limitations of common CATx Ethernet cable. Now you can connect equipment at longer distances using existing RJ11 cable while still retaining 10/100Mbps fast-Ethernet speeds.
Perfect for connecting isolated terminals, kiosks, or server rooms using single pair copper wire such as telephone cable, the extender kit lets you transmit and receive data at distances up to 5000ft (1500m) at 17Mbps, or 1000ft (300m) at 100Mbps throughput.
This handy extender helps you network separate buildings at the same location, and saves you money. Using legacy plain old telephone service (POTS), you can deliver network access across an existing phone line infrastructure, which is perfect for older buildings.
Alternatively, you can couple the extender with a single point-to-point RJ11 cable, giving you more options for providing network connections in situations where standard CATx wired or wireless access is unavailable or unreliable.
A true out-of-the-box solution, the extender kit includes interchangeable transmitter and receiver units that are completely customizable using the integrated DIP switches. Setup is fast and you can be up and running with no software or driver installation required.
The 110VDSLEX2GB also features compact housing that's perfect for desktop or wall-mount applications.
StarTech.com VDSL2 Ethernet Extender Kit Over single-pair wire - 10/100Mbps - 1.5km - short-haul modem - 10Mb LAN, 100Mb LAN, Ethernet over VDSL2
Short-haul modem
External
United Kingdom
Cabling Type
10Base-T, 100Base-TX
Max Transfer Distance
1.5 km
6.7 cm x 10.2 cm x 3.3 cm
87 g
Short-haul modem
External
United Kingdom
Wired
Cabling Type
1.5 km
Flow control, full duplex capability, auto-negotiation, VLAN support, auto-uplink (auto MDI/MDI-X), surge protection, wall mountable, Jumbo Frames support, plastic housing, 4KV ESD Protector
IEEE 802.3, IEEE 802.3u, IEEE 802.3x
1 x Ethernet 10Base-T/100Base-TX - RJ-45
2 x network cable
MTBF
10,000 hours
IEC 61000-4-2, EN 61000-4-5, FCC, RoHS
External power adapter
Installed Qty
2
2.5 Watt
6.7 cm
10.2 cm
3.3 cm
87 g
10 - 90% (non-condensing)
B9GH StarTech.com DC Power Adapter - 5V, 3A In Stock £11.75
