Turn two 2.5" SATA SSDs or HDDs into high-performance storage with RAID - for USB-C and USB-A enabled devices. Compact in size but big on performance, this dual-bay enclosure provides powerful external data storage, with ultra-fast data transfer speeds and configurable RAID modes. It's ideal for small business and home office applications, or top-performing workstations for graphic designers, engineers and other business professionals.
Create a high-capacity, external data storage solution with support for two 2.5" SSDs/HDDs in a wide range of sizes from 5 to 12.5mm, with capacities up to and beyond 2TB. This aluminum enclosure delivers fast file transfer rates with USB 3.1 Gen 2 performance, supports SATA I, II and III and is enhanced with UASP to maximize the performance and speed of your SATA III drives. It even has a fan, with built-in speed control, to keep things running smoothly.
USB 3.1 Gen 2 gives you greater bandwidth and speed, supporting transfer rates of up to 10Gbps - twice the speed of USB 3.0 (USB 3.1 Gen 1) technology. It lets you leverage the high performance of the latest SSDs and hard drives while alleviating bottlenecks in your data transfers.
The dual-bay drive enclosure comes with two USB cables for flexible use with the latest laptops and tablets equipped with a USB-C port, as well as legacy devices. It includes both USB-C to Micro B and USB-A to Micro B cables. The 2-bay enclosure is also compatible with a Thunderbolt 3 USB-C port.
Through RAID 0 support, the dual-bay enclosure lets you maximize the performance of your SATA III SSDs to achieve greater file transfer speeds. The dual-bay enclosure also supports RAID 1, Big (Spanning or Concatenation) and JBOD. With multiple RAID options, you can gain increased storage size, performance, or redundancy.
The enclosure is OS independent, requiring no additional software or drivers.
- StarTech.com USB 3.1 (10Gbps) External Enclosure for 2.5" SATA Hard Drives - RAID - 2-Bay USB Type-C Hard Drive Enclosure (S252BU313R) - storage enclosure - SATA 6Gb/s - USB 3.1 (Gen 2)
- Storage enclosure - external
- Bus Type
- USB 3.1 (Gen 2)
- Black
- Expansion Bays
- 2 x internal - 2.5"
- Hard Drive Form Factor Compatibility
- 2.5"
- Cooling fan
- Interface
- SATA 6Gb/s
- Data Transfer Rate
- 10 GBps
- Supported Devices
- Hard drive, solid state drive
- Max Storage Devices Qty
- 2
- RAID Level
- RAID 0, RAID 1, JBOD, BIG
- Product Material
- Aluminium
- Power
- AC 120/230 V
- 8.1 cm x 14.2 cm x 6 cm
- 2-year warranty
- Designed For
- P/N: PEXUSB311AC2, PEXUSB312A1C1H, PEXUSB312A2C2V, PEXUSB312C2, PEXUSB312EIC, TBLT3MM1MA, TBLT3MM2M, TBLT3MM2MA
- 2.5"
- Hard Drive Maximum Height
- 12.5 mm
- Host Bus
- USB 3.1 (Gen 2)
- Product Material
- Aluminium
- Black
- Cooling fan
Storage Controller
- Interface
- SATA 6Gb/s
- 10 GBps
- Supported Devices
- 2
- RAID Level
- Processor
- ASMedia ASM1352R
- Bays
- 2 x SATA 6Gb/s - SATA combo
- Connections
- 1 x USB 3.1 (Gen 2) - 10 pin Micro-USB Type B
- Included Accessories
- Key
- Cables Included
- 1 x USB cable - external
- Key lock, rubber feet, UASP transfer protocol, 3 LED indicators
- FCC, RoHS
- Power adapter
- Voltage Required
- AC 120/230 V
- Limited warranty - 2 years
- 8.1 cm
- 14.2 cm
- 6 cm
- 5 °C
- 35 °C
- 20 - 80%
- Designed For
StarTech.com 0.5m (1.5ft) Black SuperSpeed USB 3.0 Cable A to Micro B - M/M | In Stock | £8.41 |
StarTech.com USB 3.1 Enclosure for 2.5" SSD | In Stock | £29.35 |
StarTech.com USB 3.1 Gen 2 Single-bay Dock | In Stock | £53.60 |
StarTech.com USB 3.1 Tool-free Enclosure | In Stock | £25.00 |
StarTech.com USB 3.1 Gen 2 Dual-bay Dock | In Stock | £86.89 |
StarTech.com Dual M.2 Enclosure - RAID | In Stock | £47.71 |
StarTech.com 4 Bay SSD/HDD Docking Station | In Stock | £144.99 |
StarTech.com StarTech.com 2-Port 10Gbps USB-A/USB-C PCIe Card -USB 3.1 | In Stock | £39.85 |
