StarTech.com USB Wall Charger 34W/6.8A x4
Quicklinx: C9JNWS00 Mfr#: USB4PACBK
Colours:
Hurry, only 2 left in stock!
£25.96 ex VAT
£31.15 inc VAT
Charge two tablets and two phones simultaneously, from almost anywhere in the world. This 4-port charger lets you keep all of your mobile devices charged and ready to use, regardless of where you're located. Whether you're at home, in the office or traveling overseas, you can charge up to four devices at once.
The wall charger includes a universal power adapter, which lets you plug into any electrical socket almost anywhere in the world. No matter where you're traveling to, you can rest assured that you can keep your mobile devices charged and ready to use.
Plus, its compact design makes the charger the perfect mobile accessory for storing in your carry-on luggage. The portable USB wall charger features a folding North American plug that tucks away nicely to fit inside your laptop bag or other carrying case. And, you can easily throw in the correct international plug for wherever you're going, so that you're all set to charge your device when you arrive at your destination.
The multi-port charger features Smart IC technology, which enables it to identify what type of device is connected to each port. By recognizing the attached device, the charger delivers the optimal charge that's specific to each device.
Plus, the charger can deliver 34 watts of power in total, sharing 6.8 amps of power between all four ports. This means that you can charge two tablets and two phones at the same time.
The charger supports USB Battery Charging Specification 1.2, which ensures compatibility with a broad range of mobile devices, including the Apple iPhone and iPad, the Microsoft Surface tablet, the Samsung Galaxy Tab, Nexus phones and more.
Keep the charger at your desk and use it as a dedicated charging station for your mobile devices at home or in the office. Consolidating your USB devices onto a single multi-port USB charger offers a more efficient solution and saves space because you don't need to use multiple wall outlets or power bars.
The USB charging station features built-in safety measures to ensure that all of your devices are protected against damage from overheating, overvoltage, overcurrent or short circuiting. If the 34-watt limit is exceeded, the power being sent to the connected devices will turn off and the charger will reset itself until the load is reduced to safe levels.
Some mobile devices, such as certain Samsung and BlackBerry devices, use proprietary power connections which are not compatible with aftermarket chargers. Please consult the manufacturer's documentation to ensure compatibility with the USB4PACBK.
StarTech.com 4-Port Travel USB Wall Charger - 34W/6.8A International Travel Adapter - Portable USB Charging Station (USB4PACBK) power adapter - USB - 34 Watt
Power adapter
70 g
Output Connector Type
Total 4: USB
AC 100-240 V
Voltage Provided
5 V
Max Electric Current
6.8 A
Power Provided
34 Watt
Power Device Details
- 4 pin USB Type A - 5 V
P/N: USBLT1MW, USBLT1MWS, USBLT2MBR, USBLT2MW, USBLT30CMW, USBLTM1MBK, USBLTM1MWH, UUSBHAUB1RA, UUSBHAUB3, UUSBHAUB3LA, UUSBHAUB3RA, UUSBHAUB6IN, UUSBHAUB6RA
Power adapter
Tablet, mobile phone
70 g
Enclosure Colour
AC 100-240 V
Input Connectors
Power NEMA 1-15
Input Connectors Qty
1
Voltage Provided
5 V
Output connectors
Total 4: 4 pin USB Type A
Power Provided
34 Watt
6.8 A
Power plug adapter (EU), power plug adapter (UK), power plug adapter (AU), power plug adapter (US)
GS, FCC, RoHS, WEEE, cULus, USB Battery Charging Specification Rev. 1.2
C9JN StarTech.com USB Wall Charger 17W / 3.4A x2 In Stock £14.31
C9JN StarTech.com 2x USB Wall Charger 17W / 3.4A In Stock £14.45
C9JN StarTech.com USB Wall Charger 34W/6.8A x4 In Stock £25.96
C9JN StarTech.com 4x USB Wall Charger 34W / 6.8A In Stock £27.26
Stock Status: In stock
