Extend VGA video, USB, audio and serial signals up to 300m (1000ft) over Cat 5 or better cabling.
The SV565USAGB USB VGA KVM Console Extender w/ Serial & Audio Over Cat5 UTP (1000 ft) lets you control a server, computer or multiple computers (connected through KVM Switch) over standard Cat5 or Cat6 UTP network cable, at distances of up to 1000ft (333m) over a secure remote connection to a locked (secure) server.
Attached mounting brackets on the remote unit allow the console extender to be mounted in a convenient location, and features support for resolutions up to 1920x1080, with automatic image calibrations for out-of-the-box performance and manual controls accessible via the serial interface.
For added convenience, the Console/KVM extender supports USB computer connections, and is compatible with any brand of USB KVM Switch.
- StarTech.com USB VGA KVM Console Extender w/ Serial & Audio Over Cat5 UTP - KVM / audio / serial extender
- Form Factor
- External
- Localisation
- United Kingdom
- Transmission Medium
- CAT 5
- Max Transfer Distance
- 300 m
- 15.6 cm x 11.2 cm x 2.6 cm
- 250 g
- 2-year warranty
- Form Factor
- External
- Black
- Localisation
- United Kingdom
- Connectivity Technology
- Wired
- Max Resolution
- 1920 x 1080 @ 60 Hz
- 300 m
- Firmware upgradable
- FCC, RoHS
- Power Device
- External power adapter
- 15.6 cm
- 11.2 cm
- 2.6 cm
- 250 g
- Limited warranty - 2 years
- 0 °C
- 40 °C
