StarTech.com USB to VGA External Video Card Multi Monitor Adapter – 1920x1200
Quicklinx: 7RXXWS00 Mfr#: USB2VGAE3
More than 50 in stock
£35.66 ex VAT
£42.79 inc VAT
The USB2VGAE3 USB VGA Multi-Monitor External Video Adapter lets you add a high-resolution (1920x1200) external VGA output to your desktop or laptop computer, using an available USB 2.0 port. A cost-effective solution for systems that lack the outputs required for a multi-monitor setup, this high-performance USB to VGA adapter can be used to mirror your primary display and show the same image on both screens, or extend your desktop to double your workspace. This small form factor USB video adapter can be used with up to 4 additional (5 total) USB2VGAE3 USB video adapters, creating multiple VGA connections to add displays quickly and easily - all without having to open the computer case to add extra video cards.
StarTech.com USB to VGA External Video Card Multi Monitor Adapter 1920x1200 - external video adapter - 32 MB - grey
External video adapter
Bus Type
USB 2.0
32 MB SDRAM
Max Resolution
1920 x 1200
VGA
5.25 cm x 8.8 cm x 1.8 cm
Enclosure Colour
Grey
Bus Type
USB 2.0
Max Resolution
1920 x 1200
VGA
Size
32 MB
SDRAM
Video Output
Supported Display Graphics
XGA (1024x768), SVGA (800x600), SXGA (1280x1024), SXGA+ (1400x1050), UXGA (1600x1200), HDTV (1920x1080), 1152x864, 1280x960, 1920x1200, 1600x900, 1280x720, 1280x800, 1440x900, 1360x768, 1280x768, 1680x1050, 1280x1080
Colours Max Resolution (external)
32-bit colour
Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Windows 8 (32/64 bits), Windows 10 (32/64 bits)
Additional Requirements
USB 2.0 port
1 x USB cable - 50 cm
Software Included
Drivers & Utilities
Plug and Play, FCC, RoHS
5.25 cm
8.8 cm
1.8 cm
96 g
Enclosure Colour
Grey
-10 °C
55 °C
0 - 95% (non-condensing)
7RXX StarTech.com 6 ft Coax High Resolution Monitor VGA Video Cable - HD15 to HD15 M/M In Stock £5.74
7RXX StarTech.com 25 ft Coax High Resolution VGA Monitor Extension Cable - HD15 M/F In Stock £17.08
7RXX StarTech.com 6 ft Coax High Resolution VGA Monitor Extension Cable - HD15 M/F In Stock £5.74
7RXX StarTech.com 15 ft Coax VGA Monitor Extension Cable - HD15 M/F In Stock £11.55
7RXX StarTech.com 20 ft Coax High Resolution Monitor VGA Cable HD15 M/M In Stock £9.79
7RXX StarTech.com 1 ft Coax High Resolution Monitor VGA Video Cable - HD15 to HD15 M/M In Stock £4.72
7RXX StarTech.com 40 ft Coax High Resolution Monitor VGA Cable - HD15 M/M In Stock £21.45
Price Range Ex VAT: 0 - 50
