Connect a VGA display for an extended desktop multi-monitor USB solution. The USB2VGAPRO2 USB to VGA Adapter functions as an external graphics card for Windows and Mac computers - the perfect solution for turning your desktop or laptop computer into a dual or multi-monitor environment, all through the simplicity and convenience of USB.
The USB-VGA Adapter delivers high quality video (up to 1920x1200) for a variety of applications and is capable of simultaneously running up to five additional displays from a single computer (using four USB2VGAPRO2 External Video Adapters). The adapter connects to a host computer through a USB 2.0 port, acting as an external VGA video card to either extend or mirror the desktop shown on the existing display - without having to open the computer case.
Featuring driver support for Microsoft Windows (including Aero themes) and Mac OS X, and with video support for resolutions up to 1920x1200, this USB-VGA video adapter is the ideal solution for a wide range of operating environments as well as large-screen displays/monitors.
- StarTech.com USB to VGA Adapter - 1920x1200 - External Video & Graphics Card - Dual Monitor - Supports Mac & Windows and Mirror & Extend Mode (USB2VGAPRO2) - external video adapter - DisplayLink DL-195 - 16 MB - black
- External video adapter
- Bus Type
- USB 2.0
- Graphics Engine
- Memory
- 16 MB
- Max Resolution
- 1920 x 1200
- Interfaces Details
- VGA
- 4.35 cm x 7.8 cm x 1.55 cm
- Enclosure Colour
- Black
- 2-year warranty
- Designed For
- P/N: MXT101MM
- Bus Type
- USB 2.0
- Graphics Engine
- Max Resolution
- 1920 x 1200
- VGA
- LED indicator, USB powered
- Size
- 16 MB
- OS Required
- Microsoft Windows XP 32-bit, Ubuntu 14.04, Ubuntu 16.04, Apple MacOS X 10.6 - 10.12, Google Chrome OS 55 or later, Ubuntu 18.04, Apple macOS 11.0, Apple macOS 10.14 - 10.15, Microsoft Windows Vista / 7 / 8 / 8.1 / 10 / 11, Apple macOS 12.0, Apple macOS 13.0
- Min Processor Type
- 1.2 GHz
- Min RAM Size
- 512 MB
- Min Hard Drive Space
- 30 MB
- Cables Included
- 1 x USB cable
- Software Included
- Drivers & Utilities
- FCC, RoHS
- 4.35 cm
- 7.8 cm
- 1.55 cm
- 300 g
- Enclosure Colour
- Black
- Limited warranty - 2 years
- 10 °C
- 40 °C
- 0 - 85% (non-condensing)
- Designed For
- P/N: MXT101MM
