StarTech.com USB to Stereo Audio Adapter Converter
Quicklinx: 4YLKWS00 Mfr#: ICUSBAUDIO
15 In Stock
£14.05 ex VAT
£16.86 inc VAT
Turn a USB port into a Stereo Sound Card.
This USB to Stereo Audio Adapter Converter lets you add headsets and microphones to your computer without the need to unplug other devices!
Compliant with USB 2.0 and USB audio device specification 1.0, this USB to audio adapter couldn't be any simpler to install. Compatible with Windows 98SE and up, as well as Mac OS 9.x and later, the USB Audio Adapter integrates into any computer environment, providing superb sound quality and convenience that can't be matched.
StarTech.com USB to Stereo Audio Adapter Converter - USB stereo Adapter - USB External sound Card - Laptop sound Card (ICUSBAUDIO) - sound card
Sound card
Enclosure Type
External
Interface Type
USB 2.0
4 cm x 8 cm x 1.5 cm
54 g
White
Sound Output Mode
Stereo
Microsoft Windows Server 2012, Microsoft Windows Server 2012 R2, Microsoft Windows Server 2016, Microsoft Windows 2000/XP/Vista/7/8/8.1/10, Microsoft Windows Server 2019, Linux LTS versions only, Linux 3.5 or later, Apple MacOS X 10.6 - 10.15, Apple macOS 11.0, Apple macOS 12.0, Microsoft Windows 11, Apple macOS 13.0
P/N: MU15MMS, MU6MMS
Sound card
External
Interface Type
USB 2.0
4 cm
8 cm
1.5 cm
54 g
Enclosure Colour
White
Audio Output
Sound Output Mode
Stereo
1 x microphone - mini-phone stereo 3.5 mm , 1 x audio line-out - mini-phone stereo 3.5 mm
FCC, RoHS
Software
Drivers & Utilities
Limited warranty - 2 years , Technical support - lifetime
Resources
The following resources are available for the StarTech.com USB to Stereo Audio Adapter Converter
