StarTech.com USB to DVI External Video Card Multi Monitor Adapter – 1920x1200
Quicklinx: 7RXWWS00 Mfr#: USB2DVIE3
The USB2DVIE3 USB DVI Video Adapter offers a perfect external multi-monitor solution, enabling you to add a high-resolution (up to 1920x1200) external DVI output to your desktop or laptop computer system using an available USB 2.0 port. A cost-effective solution for systems that lack the outputs required for a multi-monitor setup, this high-performance USB to DVI adapter can be used to mirror your primary display and show the same image on both screens, or extend your desktop to double your workspace. This small form factor USB video adapter can be used with up to 4 additional (5 total) USB2DVIE3 USB video adapters, creating multiple DVI connections to add additional displays quickly and easily - all without having to open the computer case to add extra video cards.
StarTech.com USB to DVI Adapter - 1920x1200 - External Video & Graphics Card - Dual Monitor Display Adapter - Supports Windows (USB2DVIE3) - external video adapter - 32 MB - black
External video adapter
Bus Type
USB 2.0
32 MB SDRAM
Max Resolution
1920 x 1200
Interfaces Details
DVI-I (Single-Link) , VGA - with adapter
5.3 cm x 8.8 cm x 1.8 cm
Enclosure Colour
P/N: DVIDDMM10, DVIDDMM6, DVIDSMM10, DVIMM6, DVISPL1DD, HDDVIMM3, HDMIDVIMM10, HDMIDVIMM6
Bus Type
USB 2.0
Max Resolution
1920 x 1200
Interfaces Details
Size
32 MB
SDRAM
Video Output
Supported Display Graphics
XGA (1024x768), SVGA (800x600), SXGA (1280x1024), SXGA+ (1400x1050), UXGA (1600x1200), HDTV (1920x1080), 1152x864, 1280x960, WUXGA (1920 x 1200), HD (1280 x 720), 1280x800, 1440x900, 1360x768, 1280x768, WSXGA+ (1680 x 1050)
Colours Max Resolution (external)
32-bit colour
Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Windows 8 (32/64 bits), Windows 10 (32/64 bits)
1 x USB cable , 1 x DVI-I to VGA adapter
Software Included
Drivers & Utilities
FCC, RoHS
5.3 cm
8.8 cm
1.8 cm
108 g
Enclosure Colour
-10 °C
55 °C
0 - 85% (non-condensing)
7RXW StarTech.com DVI to VGA Cable Adapter - M/F In Stock £5.42
7RXW StarTech.com 6 ft HDMI to DVI-D Cable - M/M In Stock £9.37
7RXW StarTech.com USB 3.0 to DVI / VGA External Video Card Multi Monitor Adapter – 2048x1152 In Stock £73.06
7RXW StarTech.com USB 3.0 to HDMI and DVI Dual Monitor External Video Card Adapter In Stock £77.49
7RXW StarTech.com USB to DVI Adapter - External USB Video Graphics Card for PC and MAC- 1920x1200 In Stock £71.67
