The USB2DVIE3 USB DVI Video Adapter offers a perfect external multi-monitor solution, enabling you to add a high-resolution (up to 1920x1200) external DVI output to your desktop or laptop computer system using an available USB 2.0 port. A cost-effective solution for systems that lack the outputs required for a multi-monitor setup, this high-performance USB to DVI adapter can be used to mirror your primary display and show the same image on both screens, or extend your desktop to double your workspace. This small form factor USB video adapter can be used with up to 4 additional (5 total) USB2DVIE3 USB video adapters, creating multiple DVI connections to add additional displays quickly and easily - all without having to open the computer case to add extra video cards.
- StarTech.com USB to DVI Adapter - 1920x1200 - External Video & Graphics Card - Dual Monitor Display Adapter - Supports Windows (USB2DVIE3) - external video adapter - 32 MB - black
- External video adapter
- Bus Type
- USB 2.0
- Memory
- 32 MB SDRAM
- Max Resolution
- 1920 x 1200
- Interfaces Details
- DVI-I (Single-Link) , VGA - with adapter
- 5.3 cm x 8.8 cm x 1.8 cm
- Enclosure Colour
- Black
- 2-year warranty
- Designed For
- P/N: DVIDDMM10, DVIDDMM6, DVIDSMM10, DVIMM6, DVISPL1DD, HDDVIMM3, HDMIDVIMM10, HDMIDVIMM6
- Bus Type
- USB 2.0
- Max Resolution
- 1920 x 1200
- Size
- 32 MB
- Technology
- SDRAM
Video Output
- Supported Display Graphics
- XGA (1024x768), SVGA (800x600), SXGA (1280x1024), SXGA+ (1400x1050), UXGA (1600x1200), HDTV (1920x1080), 1152x864, 1280x960, WUXGA (1920 x 1200), HD (1280 x 720), 1280x800, 1440x900, 1360x768, 1280x768, WSXGA+ (1680 x 1050)
- Colours Max Resolution (external)
- 32-bit colour
- OS Required
- Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Windows 8 (32/64 bits), Windows 10 (32/64 bits)
- Cables Included
- 1 x USB cable , 1 x DVI-I to VGA adapter
- Software Included
- Drivers & Utilities
- FCC, RoHS
- 5.3 cm
- 8.8 cm
- 1.8 cm
- 108 g
- Enclosure Colour
- Black
- Limited warranty - 2 years
- -10 °C
- 55 °C
- 0 - 85% (non-condensing)
- Designed For
StarTech.com DVI to VGA Cable Adapter - M/F | In Stock | £5.42 |
StarTech.com 6 ft HDMI to DVI-D Cable - M/M | In Stock | £9.29 |
StarTech.com USB 3.0 to DVI / VGA External Video Card Multi Monitor Adapter – 2048x1152 | In Stock | £73.06 |
StarTech.com USB 3.0 to HDMI and DVI Dual Monitor External Video Card Adapter | In Stock | £77.49 |
StarTech.com USB to DVI Adapter - External USB Video Graphics Card for PC and MAC- 1920x1200 | In Stock | £71.67 |
