Product
StarTech.com USB to Dual DP Docking Station
Quicklinx: D5Z7WS00 Mfr#: USBA2DPGB
Type: Docking Stations
Colour: Black
15 in stock
£72.76 ex VAT
£87.31 inc VAT
Create a dual-monitor workstation using your laptop, adding two 4K Ultra HD displays and Gigabit Ethernet. This USB to dual DisplayPort mini docking station makes it easy to create a high-performance dual-4K workstation, connecting your MacBook or Windows laptop to two DisplayPort monitors plus Gigabit Ethernet wired network. The dock features a compact design that's perfect for business professionals who need a highly functional workstation when working or traveling between multiple office locations, or when using shared workspaces.
The mini docking station lets you transform your laptop into a highly productive workstation, by expanding the display capabilities of your laptop across two Ultra HD 4K monitors, even if your laptop video card doesn't natively support it. The USB 3.0 docking station supports low-latency, high-resolution 4K graphics on both video ports, using DisplayPort monitors. It works with any laptop that has an available USB 3.0 (USB-A) port.
The mini dock supports DisplayLink graphics technology, with the DisplayLink-6950 chipset, to provide support for dual 4Kp60 displays. With the dual-4K mini dock, you can connect: 2x 4K DisplayPort displays at 4096 x 2160 resolution @ 60Hz / 3840 x 2160 @ 60Hz; Single 5K display at 5120 × 2880 @ 60Hz.
The mini docking station is ideal for producers, graphic and web designers, engineers, architects and many other professionals who work on advanced graphics applications. It offers a fast and easy way to maximize your laptop's workable screen space, giving you three screens in total when coupled with your laptop's display.
The mini dock's compact size is ideal for business professionals working in space restricted workspaces or multiple locations, and require a high-performance dual-monitor workstation.
The Gigabit Ethernet port provides a reliable network connection in areas where Wi-Fi is limited or unavailable.
The mini docking station ensures easy plug-and-play setup with no drivers required. It's bus-powered from your laptop, so no external power adapter is required.
StarTech.com USB to Dual DisplayPort Mini Dock with GbE LAN - Dual 4K 60 Hz - docking station - 2 x DP
Docking station
Docking Interface
USB
Video Interfaces
2 x DP
5.8 cm x 13 cm x 2 cm
126 g
Gigabit Ethernet
3 years warranty
Docking station
5.8 cm
13 cm
2 cm
126 g
Enclosure Colour
IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, USB 1.1, USB 2.0, USB 3.0
2 x display / video - DisplayPort - 20 pin DisplayPort , 1 x network - 10Base-T/100Base-TX/1000Base-T - RJ-45
1 x SuperSpeed USB cable - integrated - 14 cm
Wake on LAN, USB powered, full duplex support, 4K Ultra HD, DisplayLink DL-6950 chipset
FCC, RoHS, WEEE, DisplayLink Plug and Display, RCM
Microsoft Windows 7 / 8 / 8.1 / 10, Apple MacOS X 10.10 - 10.12, Apple macOS Mojave 10.14
Limited warranty - 3 years
StarTech.com USB to Dual DP Docking Station Bundle deal on StarTech.com USB to Dual DP Docking Station
£169.75
Colour: Black
Price Range Ex VAT: 50 - 100
