StarTech.com USB Stereo Audio Adapter External Sound Card with SPDIF Digital Audio
Quicklinx: 90WRWS00 Mfr#: ICUSBAUDIO2D
Interface: USB 2.0
Sound Output Mode: Stereo
  • Windows 8 (32/64 bits)
Hurry, only 2 left in stock!
£20.86 ex VAT
£25.03 inc VAT
Add an SPDIF digital audio output and standard 3.5mm audio/microphone connections to your system through USB. The ICUSBAUDIO2D External USB Sound Card lets you add an S/PDIF digital audio output and standard 3.5mm analog audio/microphone connections to your system through USB - a convenient way to bypass or replace an internal sound card without having to open the computer case.
For home-theater quality sound, the USB DAC (digital-to-analog converter) offers 96KHz / 24-bit sampling rates for both playback and recording, and a 3.5mm S/PDIF port with support for Dolby Digital 5.1 surround sound (AC3) and DTS pass-through (5.1 surround sound is supported in Windows only).
This versatile USB audio adapter features an integrated 3.5mm 4-position TRRS connection for your headphones or combination headset/microphone. Also a convenient external volume control for quick adjustments, a hardware EQ switch for Bass or Treble boosting, and an LED status bar to display the current sampling rate.
StarTech.com USB Sound Card w/ SPDIF Digital Audio & Stereo Mic – External Sound Card for Laptop or PC – SPDIF Output (ICUSBAUDIO2D) - sound card
Sound card
Enclosure Type
External
Interface Type
USB 2.0
4.6 cm x 4.7 cm x 1.6 cm
36 g
Sound Output Mode
Stereo
DAC Resolution
24-bit
Sample Rate
96 kHz (max)
Linux, Apple MacOS X 10.x or later, Microsoft Windows Server 2008 R2, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Windows 8 (32/64 bits), Windows 10 (32/64 bits)
Sound card
External
Interface Type
USB 2.0
4.6 cm
4.7 cm
1.6 cm
36 g
Enclosure Colour
Audio Output
Sound Output Mode
Stereo
DAC Resolution
24-bit
Sample Rate
96 kHz (max)
1 x headphones - mini-phone stereo 3.5 mm , 1 x microphone - mini-phone stereo 3.5 mm , 1 x SPDIF output - mini TOSLINK
FCC, RoHS
Software
Drivers & Utilities
Limited warranty - 2 years , Technical support - lifetime
60 °C
10 - 90% (non-condensing)
90WR StarTech.com USB to Stereo Audio Adapter Converter In Stock £11.17
90WR StarTech.com USB Stereo Audio Adapter External Sound Card In Stock £11.33
90WR StarTech.com 7.1 USB Audio Adapter External Sound Card with SPDIF Digital Audio In Stock £22.55
90WR StarTech.com Virtual 7.1 USB Stereo Audio Adapter External Sound Card In Stock £12.26
90WR StarTech.com USB Stereo Audio Adapter External Sound Card with SPDIF Digital Audio In Stock £20.86
Interface: USB 2.0
Price Range Ex VAT: 0 - 50
