Your basket is empty
StarTech.com USB Easy Transfer Cable for Windows 8 Upgrade
Quicklinx: 5D49WS00 Mfr#: USB2LINK
StarTech.com's USB 2.0 Easy Transfer cable offers a convenient solution for migrating files from Windows XP or Windows Vista or Windows 7 computers to the newer Windows 8 platform, using the Windows Easy Transfer software.
Instead of having to transfer files from your old computer to your new one over a network or CD/DVD storage, this high quality data transfer cable lets you connect one Windows computer to another, directly through a USB 2.0 connection, supporting data transfer speeds of up to 480Mbps.
StarTech.com USB Easy Transfer Cable for Windows 7 Upgrade - direct connect adapter
Direct connect adapter
External
Interface (Bus) Type
USB 2.0
Ports
USB 2.0
Length
2.1 m
USB, USB 2.0
USB 2.0
Microsoft Windows Vista / XP / 7
2 years warranty
P/N: PEXUSB7LP
External
USB 2.0
Ports
USB 2.0
Wired
USB, USB 2.0
USB 2.0
1 x USB 2.0 - 4 pin USB Type A - male
FCC
Software Included
Drivers & Utilities
Length
2.1 m
StarTech.com 7 Port PCI Express Low Profile High Speed USB 2.0 Adapter Card
5D49 StarTech.com 16 ft USB 2.0 Active Extension Cable - M/F In Stock £13.61
