Product
StarTech.com USB DVI KVM Console IP Extender over Cat5 with Audio - 1680x1050 330 ft (100m)
Quicklinx: 87PSWS00 Mfr#: SV565LANDUA
Extend DVI-D (or HDMI) video, USB and Audio through a LAN, or Cat 5 cabling, up to 100m (330ft). The SV565LANDUA Dual Mode USB DVI KVM Console Extender over Cat5 (100m) or LAN lets you control a USB & DVI-D PC or KVM switch over an IP Local Area Network, or by direct Cat5 (or better) cable connection, up to 100 meters (330 feet) away.
Connecting over your existing IP LAN avoids the hassle and cost of running new infrastructure cabling, and allows for a greater overall extension distance that can easily traverse many floors of your office building. Or you can connect the local and remote units via a single Cat5 cable, providing a versatile KVM extension solution.
The DVI KVM extender supports video resolutions up to 1680x1050 at maximum distance without signal degradation, and supports 3.5mm audio/mic connections. Also featuring 3 High-Speed 480 Mbps USB 2.0 ports on the remote end, allowing you to connect a keyboard, mouse or other peripherals such as external storage drives or webcams.
StarTech.com DVI USB KVM Console IP Extender over Cat5 - 1680x1050 330ft - KVM / audio extender
External
Max Transfer Distance
100 m
AC 120/230 V
17.5 cm x 11.8 cm x 3.1 cm
420 g
2 years warranty
External
Wired
Max Resolution
1680 x 1050
100 m
Status Indicators
Status, link/activity, USB
1 x audio (output) - mini jack , 1 x microphone (input) - mini jack , 1 x display / video - DVI-Digital - DVI , 3 x USB 2.0 - Type A , 1 x USB 2.0 - Type B
FCC, RoHS
External power adapter
Installed Qty
2
AC 120/230 V
17.5 cm
11.8 cm
3.1 cm
420 g
50 °C
20 - 80% (non-condensing)
87PS StarTech.com 6 ft DVI-D Dual Link Cable - M/M In Stock £6.62
87PS StarTech.com 6ft 4-in-1 USB Dual Link DVI-D KVM Switch Cable with Audio & Microphone In Stock £16.27
87PS StarTech.com 10ft 4-in-1 USB Dual Link DVI-D KVM Switch Cable with Audio & Microphone In Stock £19.64
87PS StarTech.com 100 ft Blue Gigabit Snagless RJ45 UTP Cat6 Patch Cable In Stock £24.02
