Extend DVI-D (or HDMI) video, USB and Audio through a LAN, or Cat 5 cabling, up to 100m (330ft). The SV565LANDUA Dual Mode USB DVI KVM Console Extender over Cat5 (100m) or LAN lets you control a USB & DVI-D PC or KVM switch over an IP Local Area Network, or by direct Cat5 (or better) cable connection, up to 100 meters (330 feet) away.
Connecting over your existing IP LAN avoids the hassle and cost of running new infrastructure cabling, and allows for a greater overall extension distance that can easily traverse many floors of your office building. Or you can connect the local and remote units via a single Cat5 cable, providing a versatile KVM extension solution.
The DVI KVM extender supports video resolutions up to 1680x1050 at maximum distance without signal degradation, and supports 3.5mm audio/mic connections. Also featuring 3 High-Speed 480 Mbps USB 2.0 ports on the remote end, allowing you to connect a keyboard, mouse or other peripherals such as external storage drives or webcams.
- StarTech.com DVI USB KVM Console IP Extender over Cat5 - 1680x1050 330ft - KVM / audio extender
- Form Factor
- External
- Transmission Medium
- CAT 5
- Max Transfer Distance
- 100 m
- Power
- AC 120/230 V
- 17.5 cm x 11.8 cm x 3.1 cm
- 420 g
- 2-year warranty
- Form Factor
- External
- Black
- Connectivity Technology
- Wired
- Max Resolution
- 1680 x 1050
- 100 m
- Status Indicators
- Status, link/activity, USB
- 1 x audio (output) - mini jack , 1 x microphone (input) - mini jack , 1 x display / video - DVI-Digital - DVI , 3 x USB 2.0 - Type A , 1 x USB 2.0 - Type B
- FCC, RoHS
- Power Device
- External power adapter
- Installed Qty
- 2
- Voltage Required
- AC 120/230 V
- 17.5 cm
- 11.8 cm
- 3.1 cm
- 420 g
- Limited warranty - 2 years
- 0 °C
- 50 °C
- 20 - 80% (non-condensing)
