Product
StarTech.com USB DVI KVM Console Extender w/ True USB 2.0 and Audio - 500m
Quicklinx: 7P3BWS00 Mfr#: SV565UTPDUA
The SV565UTPDUA USB 2.0 DVI KVM Console Extender w/ Audio lets you operate a USB & DVI-D (Digital) KVM or PC up to 500 meters (1640 feet) away, over Cat5 (or better) cable, as if it were right in front of you.
This versatile console extender features 3 High-Speed USB 2.0 ports, allowing you to connect your keyboard & mouse. Unlike other extenders however, the SV565UTPDUA supports real USB 2.0 signal over long distances, so you can also connect an external hard drive, thumb-drive, webcam, or any other USB peripheral and communicate at full USB 2.0 speeds (480Mbps). For additional connectivity, this device supports the use of USB hubs for a maximum of 13 USB connections total, for a true PC control experience as if you were on-site.
Supporting DVI-D resolutions up to 1680x1050, the DVI KVM Console Extender provides crystal clear, high definition video and also supports 3.5mm audio and microphone connections. Extension over Cat 5 (or better) network cabling offers the freedom to set up your remote user station using existing infrastructure wiring, avoiding the need to run bulky video cables.
StarTech.com USB DVI KVM Console Extender w/ True USB 2.0 and Audio - 500m - KVM / audio / USB extender
External
Max Transfer Distance
500 m
17.5 cm x 11.2 cm x 3 cm
400 g
2 years warranty
P/N: SV831DVIU
External
Wired
Max Resolution
1600 x 1050
500 m
Status Indicators
Status
1 x audio (output) - mini jack , 1 x microphone (input) - mini jack , 1 x display / video - DVI-Digital - DVI , 3 x USB 2.0 - Type A , 1 x USB 2.0 - Type B
1 x DVI cable , 1 x USB cable
FCC, RoHS
External power adapter
Installed Qty
2
17.5 cm
11.2 cm
3 cm
400 g
50 °C
20 - 80%
P/N: SV831DVIU
7P3B StarTech.com 6 ft 3.5mm Stereo Audio Cable - M/M In Stock £3.37
7P3B StarTech.com 6 ft DVI-D Dual Link Cable - M/M In Stock £6.71
7P3B StarTech.com 10 ft DVI-D Dual Link Cable - M/M In Stock £10.60
7P3B StarTech.com 10 ft USB 2.0 Certified A to B Cable - M/M In Stock £3.81
7P3B StarTech.com 6 ft USB 2.0 Certified A to B Cable - M/M In Stock £3.15
7P3B StarTech.com 6in Stereo Audio Cable - 3.5mm Male to 2x RCA Female In Stock £2.83
