Your basket is empty
StarTech.com USB DVI KVM Console Extender w/ Serial & Audio Over MM Fiber - 2km
Quicklinx: 76QLWS00 Mfr#: SV565FXDUSA
£1,744.86 ex VAT
£2,093.83 inc VAT
High Definition Digital DVI (or HDMI), USB, Audio, and Serial extension and control up to 2000 m (6562 ft) away over fiberThe SV565FXDUSA USB DVI serial and audio KVM Console Extender lets you control a server, computer or multiple computers (connected through KVM Switch) over a multi-mode fiber link, at distances of up to 2000m (6562 ft) away.
For added convenience, the Console/KVM extender supports USB computer connections, and is compatible with any brand of USB KVM Switch.
By transmitting the digital DVI video (or HDMI with a DVI to HDMI adapter) over a multi-mode optical fiber link, there is no signal loss so the video is as sharp and vivid as it would be if the monitor was connected directly to the PC.
The USB DVI Console Extender is designed to provide long-lasting, reliable operation.
StarTech.com USB DVI KVM Console Extender w/ Serial & Audio Over MM Fiber - 2km - KVM / audio / serial extender
KVM / audio / serial extender - USB
External
Max Transfer Distance
2 km
3 years warranty
P/N: SV831DVIU
External
Wired
Keyboard / Mouse Interface
USB
Max Resolution
1920 x 1200 / 1080p
2 km
Status Indicators
Power, transmit, receive
1 x audio (input) - mini jack , 1 x microphone (input) - mini jack , 1 x serial - DB-9 male , 1 x serial - DB-9 female , 2 x video - DVI-Analog/Digital - 23 pin combined DVI (Single-Link) , 2 x USB - Type A , 1 x USB - Type B
FCC, RoHS
External power adapter
Limited warranty - 3 years
0 - 80%
P/N: SV831DVIU
76QL StarTech.com Rack Bracket For SV431/D In Stock £17.15
76QL StarTech.com 6 ft 4-in-1 USB DVI KVM Cable with Audio and Microphone In Stock £14.15
76QL StarTech.com 1U Rackmount Brackets for KVM Switch (SV431 Series) In Stock £17.15
Price Range Ex VAT: 1500+
