This 10ft 4-in-1 USB DVI KVM switch cable provides DVI video, USB mouse and keyboard, 3.5mm audio, and 3.5mm microphone connections, all in a single, compact cable. This high quality KVM switch cable is a reliable and hassle-free way to connect USB DVI KVM switches.
- StarTech.com 4-in-1 USB DVI KVM Cable - Keyboard / video / mouse / audio extender - 4 pin USB Type A, mini-phone stereo 3.5 mm , DVI-I (USBDVI4N1A10) - keyboard / video / mouse / audio extension cable - 3 m
- Keyboard / video / mouse / audio extension cable
- Length
- 3 m
- Connectors
- 4 pin USB Type A - female , 24+5 pin combined DVI - male , 2 x mini-phone stereo 3.5 mm - male
- Connectors (Second End)
- 4 pin USB Type A - female , 24+5 pin combined DVI - male , 2 x mini-phone stereo 3.5 mm - male , 4 pin USB Type B
- Black
- Limited lifetime warranty
- Designed For
- P/N: SV231DVIUA, SV231UADVI, SV431DVIUA, SV431DVIUAGB, SV565FXDUSA
- Length
- 3 m
- Black
- Connectors
- Designed For
StarTech.com 4 Port Dual DVI USB KVM Switch with Audio & USB 2.0 Hub | In Stock | £269.04 |
StarTech.com 4 Port DVI VGA Dual Monitor KVM Switch USB with Audio & USB 2.0 Hub | In Stock | £277.79 |
StarTech.com 2 Port Dual DVI USB KVM Switch with Audio & USB 2.0 Hub | In Stock | £197.20 |
StarTech.com 2 Port DVI VGA Dual Monitor KVM Switch USB with Audio & USB 2.0 Hub | In Stock | £166.96 |
StarTech.com 2 Port DVI USB KVM Switch with Audio and USB 2.0 Hub | In Stock | £141.16 |
StarTech.com 2 Port High Resolution USB DVI Dual Link KVM Switch with Audio | In Stock | £204.94 |
StarTech.com 4 Port High Resolution USB DVI Dual Link KVM Switch with Audio | In Stock | £308.73 |
