StarTech.com USB Dual VGA over Cat5 KVM Console Extender - 650 ft / 200m
Quicklinx: 8D6LWS00 Mfr#: SV565DUTPU
13 In Stock
£377.62 ex VAT
£453.14 inc VAT
The SV565DUTPU USB Dual VGA KVM Console Extender over CAT5 UTP lets you Operate a Dual VGA PC or KVM switch up to 650ft (200 m) away, as if it was installed locally, at high-definition 1920x1200 resolution. PC connection cables are included with this product for a ready to use solution.
The dual VGA cat5 KVM extender supports easy to use hot-key and push button commands which allow you to switch between local and remote connected systems, while console connections at both ends of your setup provide easy access to all connected systems from either location. The hot-key commands also provide video adjustment controls for optimizing picture quality over varying distances. Extending over two standard Cat 5 (or better) cables gives you the ability to use existing infrastructure wiring to achieve remote access to your server or KVM switch.
StarTech.com 650 ft/200m USB 2.0 Dual VGA KVM Console Extender over Cat5 UTP -for Dual VGA, USB-enabled PC or KVM Switch - Upto 1920x1200 (SV565DUTPU) - KVM extender
KVM extender
External
Transmission Medium
CAT 5
Max Transfer Distance
200 m
AC 120/230 V
8 cm x 15.5 cm x 4 cm
0.54 kg
3-year warranty
P/N: SVA12M2NEUA, SVA12M5NA
KVM extender
External
Wired
Max Resolution
1920 x 1200
200 m
2 x USB - Type A , 2 x VGA - HD-15
2 x keyboard / mouse / video / USB cable - 1.8 m
External power adapter
AC 120/230 V
8 cm
15.5 cm
4 cm
0.54 kg
Limited warranty - 3 years
0 - 80%
8D6L StarTech.com 6 ft 2-in-1 Ultra Thin USB KVM Cable In Stock £7.06
8D6L StarTech.com 10 ft Ultra Thin USB VGA 2-in-1 KVM Cable In Stock £10.60
8D6L StarTech.com 15 ft 2-in-1 Ultra Thin USB KVM Cable In Stock £15.89
8D6L StarTech.com USB HDMI over Cat 5e Cat 6 KVM Console Extender - 1080p Uncompressed Video 330ft (100m) In Stock £692.95
8D6L StarTech.com DC Power Adapter - 9V, 2A In Stock £12.06
8D6L StarTech.com DC Power Adapter - 12V, 2A In Stock £12.66
8D6L StarTech.com DC Power Adapter - 12V, 5A In Stock £41.16
