StarTech.com USB C VGA Multiport Adapter
Quicklinx: DQZ3WS00 Mfr#: DKT30CVAGPD
£55.54 ex VAT
£66.64 inc VAT
Power and charge your laptop, and create a workstation by connecting to a VGA monitor, GbE, and a USB 3.0 device. Expand the connectivity of your USB-C laptop with this USB-C VGA multiport adapter. It connects to your USB-C or Thunderbolt 3 port to add VGA video output, a USB 3.0 (Type-A) port with Fast-Charge capability plus a Gigabit Ethernet network connection. Mac, Windows and Chrome OS compatible, it's the ideal accessory for your MacBook, laptop, tablet, Chromebook, smartphone or other USB-C device (with support for DisplayPort Alt Mode).
This USB-C adapter lets you connect your USB-C laptop or device to an external VGA monitor or projector to give engaging presentations in the boardroom, classroom, or meeting room. It supports HD video resolutions up to 1920 x 1200p @ 60Hz.
Compact and durable, the USB-C multiport adapter is ideal for mobile use, eliminating the need to carry multiple adapters with you. Set up a workstation with a Gigabit Ethernet port and a USB 3.0 port to connect an existing USB device or fast-charge your smartphone or tablet. The adapter features a USB-C port that supports USB Power Delivery 2.0 (60W) so you can use your laptop's USB-C power adapter to power both your laptop and the multiport adapter.
The adapter features an attached cable (5.6 in. / 143 mm) to ensure easy setup and supports plug-and-play installation, with no additional software or drivers required.
  • Connect to a VGA monitor to give presentations
  • Create a portable workstation
    Compact and durable, the USB-C multiport adapter is ideal for mobile use, eliminating the need to carry multiple adapters with you. Set up a workstation with a Gigabit Ethernet port and a USB 3.0 port to connect an existing USB device, or fast-charge your smartphone or tablet. The adapter features a USB-C port that supports USB Power Delivery 2.0 (60W) so you can use your laptop's USB-C power adapter to power both your laptop and the multiport adapter.
  • Fast and easy setup
    The adapter features an attached cable (5.6 in. / 143 mm) to ensure easy setup and supports plug-and-play installation, with no additional software or drivers required. The DKT30CVAGPD is backed by a StarTech.com 3-year warranty and free lifetime technical support.
StarTech.com USB C Multiport Adapter, Mini USB-C Dock with Single Monitor VGA 1080p Video, 60W Power Delivery Passthrough, USB 3.1 Gen 1 Type-A 5Gbps, Gigabit Ethernet, Docking Station - Portable USB C Dock (DKT30CVAGPD) - docking station - USB-C - VGA - 1GbE
Docking station
Docking Interface
USB-C
Video Interfaces
VGA
4 cm x 9.6 cm x 1.65 cm
46.9 g
Gigabit Ethernet
3-year warranty
Docking station
4 cm
9.6 cm
1.65 cm
46.9 g
Enclosure Colour
Video
Max Resolution Details
1920 x 1200 - 60 Hz
IEEE 802.3, IEEE 802.3u, IEEE 802.3ab
1 x network - 1000Base-T - RJ-45 , 1 x SuperSpeed USB 3.0 with Fast Charging - 9 pin USB Type A , 1 x USB-C with Power Delivery - 24 pin USB-C (power only) , 1 x video - VGA - 15 pin HD D-Sub (HD-15)
1 x USB-C cable - integrated - 14.3 m
USB powered, full duplex support, 60W power delivery
FCC, RoHS, USB Battery Charging Specification Rev. 1.2, USB Power Delivery 2.0, UASP (USB Attached SCSI Protocol)
Google Chrome OS 55 or later, Apple MacOS X 10.11 - 10.15, Apple macOS 11.0, Microsoft Windows 7 / 8 / 8.1 / 10 / 11, Apple macOS 12.0, Apple macOS 13.0
Limited warranty - 3 years
Shipping Weight
60 g
45 °C
DQZ3 StarTech.com 1m (3ft) Certified SuperSpeed USB 3.0 A to Micro B Cable - M/M In Stock £10.90
DQZ3 StarTech.com 0.5m (1.5ft) Black SuperSpeed USB 3.0 Cable A to Micro B - M/M In Stock £8.41
DQZ3 StarTech.com 1m USB 3.1 USB-C to USB-A Cbl In Stock £9.82
DQZ3 StarTech.com USB-C to VGA - Power Delivery In Stock £23.19
DQZ3 StarTech.com USB-C to VGA Adapter with PD In Stock £41.47
DQZ3 StarTech.com 0.5m USB 2.0 C to A Cable M/M In Stock £7.99
DQZ3 StarTech.com USB-C to VGA, DVI or HDMI In Stock £41.85
