StarTech.com USB C VGA Multiport Adapter
Quicklinx: DQZ3WS00 Mfr#: DKT30CVAGPD
47 in stock
£37.41 ex VAT
£44.89 inc VAT
Power and charge your laptop, and create a workstation by connecting to a VGA monitor, GbE, and a USB 3.0 device. Expand the connectivity of your USB-C laptop with this USB-C VGA multiport adapter. It connects to your USB-C or Thunderbolt 3 port to add VGA video output, a USB 3.0 (Type-A) port with Fast-Charge capability plus a Gigabit Ethernet network connection. Mac, Windows and Chrome OS compatible, it's the ideal accessory for your MacBook, laptop, tablet, Chromebook, smartphone or other USB-C device (with support for DisplayPort Alt Mode).
This USB-C adapter lets you connect your USB-C laptop or device to an external VGA monitor or projector to give engaging presentations in the boardroom, classroom, or meeting room. It supports HD video resolutions up to 1920 x 1200p @ 60Hz.
Compact and durable, the USB-C multiport adapter is ideal for mobile use, eliminating the need to carry multiple adapters with you. Set up a workstation with a Gigabit Ethernet port and a USB 3.0 port to connect an existing USB device or fast-charge your smartphone or tablet. The adapter features a USB-C port that supports USB Power Delivery 2.0 (60W) so you can use your laptop's USB-C power adapter to power both your laptop and the multiport adapter.
The adapter features an attached cable (5.6 in. / 143 mm) to ensure easy setup and supports plug-and-play installation, with no additional software or drivers required.
StarTech.com USB C VGA Multiport Adapter - Power Delivery - USB 3.0 - GbE - docking station - VGA
Docking station
Docking Interface
USB-C
Video Interfaces
VGA
4 cm x 9.6 cm x 1.65 cm
46.9 g
Gigabit Ethernet
3-year warranty
Docking station
4 cm
9.6 cm
1.65 cm
46.9 g
Enclosure Colour
Video
Max Resolution Details
1920 x 1200 - 60 Hz
IEEE 802.3, IEEE 802.3u, IEEE 802.3ab
1 x network - 1000Base-T - RJ-45 , 1 x SuperSpeed USB 3.0 with Fast Charging - 9 pin USB Type A , 1 x USB-C with Power Delivery - 24 pin USB-C (power only) , 1 x video - VGA - 15 pin HD D-Sub (HD-15)
1 x USB-C cable - integrated - 14.3 m
USB powered, full duplex support, 60W power delivery
FCC, RoHS, USB Battery Charging Specification Rev. 1.2, USB Power Delivery 2.0, UASP (USB Attached SCSI Protocol)
Microsoft Windows 7 / 8 / 8.1 / 10, Apple MacOS X 10.11 - 10.13, Google Chrome OS 55 or later
Limited warranty - 3 years
Shipping Weight
60 g
45 °C
DQZ3 StarTech.com 6 ft Coax High Resolution Monitor VGA Video Cable - HD15 to HD15 M/M In Stock £5.74
DQZ3 StarTech.com 1m USB 3.1 USB-C to USB-A Cbl In Stock £9.41
DQZ3 StarTech.com USB-C Multifunction Adapter 4K In Stock £54.49
DQZ3 StarTech.com USB-C to VGA - Power Delivery In Stock £23.95
DQZ3 StarTech.com USB-C to VGA Adapter with PD In Stock £30.47
DQZ3 StarTech.com 0.5m USB 2.0 C to A Cable M/M In Stock £5.68
DQZ3 StarTech.com USB-C Multiport Adapter - HDMI In Stock £55.84
DQZ3 StarTech.com USB-C to VGA, DVI or HDMI In Stock £37.55
Price Range Ex VAT: 0 - 50
