Connect your MacBook, Chromebook or laptop with USB Type-C to a VGA monitor or projector. This USB-C to VGA video adapter lets you output high-definition VGA video from your USB Type-C device.
USB Type-C is a universal connectivity standard that combines all of your essential functions into one dynamic port. The connector is featured on ultra-portable devices with USB 3.1 Gen 1. This adapter works with USB-C devices that pass a DisplayPort video signal, such as the MacBook and Chromebook Pixel . It's also compatible with Thunderbolt 3 ports.
This USB Type-C video adapter maximizes portability with a lightweight, small-footprint design, which makes it the perfect accessory to carry with your MacBook or Chromebook, fitting easily into your laptop bag or carrying case. This ultra-portable design makes this adapter perfect for BYOD (Bring Your Own Device) applications at the office.
This adapter lets you utilize the versatile USB Type-C port on your portable device. USB Type-C is a reversible connector, so no matter how you plug it in, the adapter will always work, saving you the hassle and embarrassment of struggling with your device when you're trying to present.
The adapter supports video resolutions up to 1920x1200 or 1080p. You'll be surprised at the picture quality the adapter provides, even when connected to a legacy VGA monitor, projector or television. The adapter harnesses the video capabilities built into your USB Type-C connection to deliver every detail in stunning high-definition.
Note: Your USB-C equipped device must support video to work with this adapter. The adapter will not output digitally encrypted content.
- StarTech.com USB-C to VGA Adapter - Black - 1080p - Video Converter For Your MacBook Pro - USB C to VGA Display Dongle (CDP2VGA) - USB / VGA adapter - 24 pin USB-C to HD-15 (VGA) - 18 cm
- USB / VGA adapter
- USB power, 1920 x 1200 (WUXGA) support, DisplayPort Alternate Mode support
- Length
- 18 cm
- Connector
- 24 pin USB-C - male (input)
- Connector (Second End)
- 15 pin HD D-Sub (HD-15) - female (output)
- USB 3.1 Gen 1 / Thunderbolt 3
- Black
- 3-year warranty
- Designed For
- P/N: BNDTB10GI, BNDTB1394B3, BNDTB210GSFP, BNDTB310GNDP, BNDTB410GSFP, BNDTB4M2E1, BNDTBUSB3142, TB31PCIEX16, TB33A1C, TB3DK2DPPD, TB3DK2DPPDUE, TB3DK2DPW, TB3DK2DPWUE, TB3DKDPMAW, TB3DKDPMAWUE, TB4CDOCK
- USB / VGA adapter
- Length
- 18 cm
- Black
- 3.7 cm
- 1.4 cm
- 24 g
- Connector
- USB 3.1 Gen 1 / Thunderbolt 3, FCC, RoHS
- Shipping Width
- 12.5 cm
- Shipping Depth
- 22.5 cm
- Shipping Height
- 1.7 cm
- Shipping Weight
- 29 g
- 3-year warranty
- Designed For
StarTech.com USB-C to VGA Adapter - White | In Stock | £21.61 |
StarTech.com USB-C to HDMI Adapter | In Stock | £22.69 |
StarTech.com USB-C to DisplayPort Adapter Cable 1m (3 ft.) - 4K at 60 Hz | In Stock | £32.27 |
StarTech.com 6ft USB-C to DisplayPort Cable | In Stock | £28.80 |
StarTech.com 2m USB-C to DVI Cable | In Stock | £24.14 |
StarTech.com 2m USB-C to HDMI Cable | In Stock | £31.44 |
StarTech.com USB-C to VGA - Power Delivery | In Stock | £23.19 |
StarTech.com 1m USB-C to DVI Cable | In Stock | £22.16 |
StarTech.com USB-C to HDMI Adapter - 4K60Hz | In Stock | £16.82 |
StarTech.com 1m USB-C to HDMI Cable | In Stock | £27.99 |
StarTech.com USB-C to HDMI - Power Delivery | In Stock | £25.73 |
StarTech.com USB-C to DisplayPort Adapter | In Stock | £23.87 |
StarTech.com USB-C to HDMI Presentation | In Stock | £40.26 |
StarTech.com USB-C to DisplayPort Adapter | In Stock | £23.09 |
StarTech.com USB-C to DVI with USB PD | In Stock | £17.71 |
StarTech.com USB-C to DP with USB PD | In Stock | £31.36 |
StarTech.com 1m USB C to DP Cable - White | In Stock | £24.72 |
StarTech.com 6 ft USB C to DP Cable - White | In Stock | £28.24 |
StarTech.com 2m USB C to HDMI Cable - Black | In Stock | £27.71 |
StarTech.com 1m USB C to HDMI Cable - Black | In Stock | £27.65 |
StarTech.com 3m USB C to DisplayPort Cable - White | In Stock | £30.46 |
StarTech.com 3m USB C to DisplayPort Cable - Black | In Stock | £32.46 |
StarTech.com 3m USB C to HDMI Cable - Black | In Stock | £28.99 |
StarTech.com 1m USB C to HDMI Cable - White | In Stock | £24.31 |
StarTech.com 1.8m 6 ft USB C to mDP Cable | In Stock | £26.59 |
StarTech.com Mini DisplayPort Cable - 4K 60Hz - Black - 3 ft / 1m | In Stock | £32.54 |
StarTech.com 5.9 ft (1.8 m) - USB-C to DisplayPort Adapter Cable | In Stock | £18.36 |
StarTech.com USB-C to DVI Adapter - Dual-Link Connectivity - Active Conve | In Stock | £40.69 |
StarTech.com 3.3 ft. (1 m) - USB-C to DisplayPort Adapter Cable - 8K | In Stock | £25.52 |
StarTech.com 3.3 ft. (1 m)?USB C to DisplayPort 1.4 Cable? | In Stock | £23.00 |
StarTech.com 6.6?ft.?(2 m)?USB C to DisplayPort 1.4 Cable | In Stock | £24.71 |
StarTech.com 3.3 ft. (1 m) USB C to DisplayPort 1.2 Cable | In Stock | £27.49 |
StarTech.com 6.6 ft. (2 m) USB C to DisplayPort 1.2 Cable | In Stock | £29.45 |
StarTech.com Portable USB C to HDMI Adapter with Keychain | In Stock | £18.81 |
StarTech.com Portable USB C to Mini DisplayPort Adapter w/ Keychain | In Stock | £11.28 |
StarTech.com Portable USB C to VGA Adapter w/ Keychain | In Stock | £10.42 |
StarTech.com USB C to DisplayPort Adapter - Power Delivery - 8K 30Hz | In Stock | £32.41 |
StarTech.com USB C to DP Adapter - 8K/4K | In Stock | £23.32 |
StarTech.com USB C to mDP Adapter 12" Cable | In Stock | £25.88 |
