StarTech.com USB-C to VGA Adapter - White
Quicklinx: BJX1WS00 Mfr#: CDP2VGAW
More than 50 in stock
£21.53 ex VAT
£25.83 inc VAT
Connect your MacBook, Chromebook or laptop with USB Type-C to a VGA monitor or projector. This USB-C to VGA video adapter lets you output high-definition VGA video from your USB Type-C device.
USB Type-C is a universal connectivity standard that combines all of your essential functions into one dynamic port. The connector is featured on ultra-portable devices with USB 3.1 Gen 1. This adapter works with USB-C devices that pass a DisplayPort video signal, such as the MacBook and Chromebook Pixel . It's also compatible with Thunderbolt 3 ports.
This USB Type-C video adapter maximizes portability with a lightweight, small-footprint design. It's the perfect accessory to carry with your MacBook or Chromebook, because it fits easily into your laptop bag or carrying case. This ultra-portable design makes this adapter perfect for BYOD (Bring Your Own Device) applications at the office.
This adapter lets you take advantage of the versatile USB Type-C port on your portable device. The USB Type-C connector is reversible, so no matter how you plug it in, the adapter will always work, which saves you the hassle and embarrassment of struggling with your device when you're trying to deliver a presentation or collaborate with a colleague.
The adapter supports video resolutions up to 1920x1200 or 1080p. You'll be surprised at the picture quality the adapter provides, even when connected to a legacy VGA monitor, projector or television. The adapter harnesses the video capabilities that are built into your USB Type-C connection, to deliver every detail in stunning high-definition.
The CDP2VGAW features a white housing that looks great with your MacBook.
Your USB-C equipped device must support video to work with this adapter. The adapter will not output digitally encrypted content.
StarTech.com USB-C to VGA Adapter - White - 1080p - Video Converter For Your MacBook Pro / Projector / VGA Display (CDP2VGAW) - external video adapter - white
External video adapter
Bus Type
USB-C
Max Resolution
1920 x 1200
VGA
Enclosure Colour
White
3-year warranty
Apple MacBook
Bus Type
USB-C
Max Resolution
1920 x 1200
VGA
USB powered
FCC, RoHS
Enclosure Colour
White
Limited warranty - 3 years
Apple MacBook
BJX1 StarTech.com USB-C to VGA Adapter In Stock £23.65
BJX1 StarTech.com USB-C to VGA Adapter - White In Stock £21.53
BJX1 StarTech.com USB-C to VGA - Power Delivery In Stock £23.95
BJX1 StarTech.com 1m USB-C to VGA Cable In Stock £25.54
BJX1 StarTech.com 2m USB-C to VGA Cable In Stock £27.44
BJX1 StarTech.com USB-C to HDMI - Power Delivery In Stock £25.54
Price Range Ex VAT: 0 - 50
