Keep this compact converter with your laptop while you're traveling, to connect to virtually any monitor, television or projector. This 3-in-1 travel adapter offers a portable solution for connecting your USB-C computer to a VGA, DVI, or HDMI display.
The travel adapter is compatible with your DP alt mode computer. DP alt mode means your computer can pass a DisplayPort video signal through the USB-C port.
This travel adapter comes with a built-in black USB-C cable and works well with your Dell XPS, MacBook and any device that supports USB-C DP alt mode.
Instead of carrying three separate video adapters in your laptop bag, this 3-in-1 adapter gives you all the video outputs you'll need. With VGA, DVI and HDMI outputs, this adapter lets you connect from your laptop's USB Type-C port to almost any boardroom or classroom display, without the inconvenience of carrying a separate adapter for each display type.
With support for multiple video outputs and a small-footprint design, this adapter is the ideal plug-and-play solution for travel or BYOD (Bring Your Own Device) applications around the office.
The adapter features a built-in cable fastener. Simply tuck the cable into place along the side of the adapter for quick and secure storage while you're traveling to ensure the adapter is neatly stored in your travel bag.
The HDMI output on this travel adapter supports Ultra HD 4K resolutions, providing four times the picture quality of high-definition 1080p. The HDMI output is also backward compatible with lower resolutions, such as 1080p and 720p, so the adapter is also perfect for your legacy video equipment. The VGA and DVI outputs also support high-definition maximum resolutions of up to 1920 x 1200, so you can still enjoy excellent video quality.
The travel adapter is compatible with USB Type-C Intel Thunderbolt 3 devices that are capable of outputting a DisplayPort signal.
- StarTech.com USB C Multiport Adapter - UHD 4K - USB C to VGA / DVI / HDMI - USB C Adapter - USB-C VGA Multiport Adapter (CDPVGDVHDB) - adapter - HDMI / DVI / VGA / USB - 11 cm
- Cable
- Adapter - HDMI / DVI / VGA / USB
- Max Output Resolution
- 3840 x 2160 - 30 Hz
- Length
- 11 cm
- Black, silver
- Connectors
- 24 pin USB-C - male (input)
- Connectors (Second End)
- HDMI - female (output) , HD-15 (VGA) - female (output) , DVI-I - female (output)
- Displayport 1.2/Thunderbolt 3
- Active converter, 4K30Hz (3840 x 2160) support (HDMI), 1920 x 1200 (WUXGA) support 60Hz (DVI and VGA)
- 3-year warranty
- Cable Type
- Adapter active converter, 4K30Hz (3840 x 2160) support (HDMI), 1920 x 1200 (WUXGA) support 60Hz (DVI and VGA)
- Interface Supported
- Length
- 11 cm
- DisplayPort Alternate Mode support, 7.1 channel Surround Sound
- Black, silver
Adapters & Converters
- 3840 x 2160
- Refresh Rate
- 30 Hz
- OS Required
- Apple macOS Sierra 10.12.6 or later
- Connectors
- 19 pin HDMI Type A - female (output) , 15 pin HD D-Sub (HD-15) - female (output) , 24+5 pin combined DVI - female (output)
- FCC, RoHS
- 6 cm
- 1.8 cm
- 67 g
- Shipping Width
- 14.4 cm
- Shipping Depth
- 17.4 cm
- Shipping Height
- 3.2 cm
- Shipping Weight
- 165 g
- Limited warranty - 3 years
StarTech.com 3m High Speed HDMI Cable - Ultra HD 4k x 2k HDMI Cable - HDMI to HDMI M/M | In Stock | £11.42 |
StarTech.com 2m High Speed HDMI Cable – Ultra HD 4k x 2k HDMI Cable – HDMI to HDMI M/M | In Stock | £8.38 |
StarTech.com 1m High Speed HDMI Cable – Ultra HD 4k x 2k HDMI Cable – HDMI to HDMI M/M | In Stock | £7.72 |
StarTech.com USB-C Multifunction Adapter | In Stock | £55.99 |
StarTech.com USB-C to VGA Adapter with PD | In Stock | £41.47 |
StarTech.com USB-C Adapter - PD - Silver | In Stock | £29.75 |
StarTech.com USB C Adapter - 4K HDMI, GbE | In Stock | £57.72 |
StarTech.com USB-C Multiport Adapter - DVI | In Stock | £51.00 |
StarTech.com USB-C to VGA, DVI or HDMI | In Stock | £41.85 |
StarTech.com USB-C Multiport Adapter Docking Station | In Stock | £129.92 |
StarTech.com USB-C Multiport Adapter with Unfolding Cable - HDMI1.4 - USB | In Stock | £71.32 |
StarTech.com USB C to VGA and HDMI Adapter - Aluminum - USB-C Multiport Adapter - 6" Built-In Cable | In Stock | £32.60 |
StarTech.com USB-C to HDMI Adapter with HDR - 4K 60Hz - Black - USB Type C to HDMI Converter | In Stock | £19.81 |
StarTech.com USB C Multiport Video Adapter - VGA or Mini DisplayPort - HD | In Stock | £22.45 |
StarTech.com USB C Multiport Video Adapter - HDMI or DisplayPort - HDR 4K60 - Display Adapter | In Stock | £33.34 |
StarTech.com USB C Multiport Video Adapter - VGA or DisplayPort - HDR 4K60 - Display Adapter | In Stock | £16.89 |
StarTech.com USB C Multiport Video Adapter - HDMI or Mini DisplayPort -HDR 4K Display Adapter | In Stock | £32.99 |
StarTech.com USB C Multiport Adapter - USB-C to 4K HDMI/PD/USB -Mini Dock | In Stock | £25.71 |
StarTech.com USB C Multiport Adapter 4K | In Stock | £64.11 |
StarTech.com USBC Multiport Adapter 4K HDMI | In Stock | £29.79 |
StarTech.com USB-C Multiport Adapter HDMI | In Stock | £68.24 |
StarTech.com USB C Multiport Adapter | In Stock | £25.68 |
StarTech.com USB C to HDMI Adapter 4K 60Hz | In Stock | £19.65 |
StarTech.com Multiport Adapter HDMI/VGA | In Stock | £64.01 |
StarTech.com USB C Multiport Adapter, 4K | In Stock | £34.69 |
StarTech.com USB C Multiport Adapter 4K | In Stock | £49.51 |
StarTech.com USBC Multiport Adapter 4K 60Hz | In Stock | £82.20 |
StarTech.com USB C Multiport Adapter 2 HDMI | In Stock | £73.52 |
StarTech.com USBC Multiport Adapter 4K 60Hz | In Stock | £79.09 |
StarTech.com USB-C Multiport Adapter | In Stock | £75.53 |
StarTech.com USB C Multiport Adapter | In Stock | £108.26 |
StarTech.com USB-C Multiport Adapter, HDMI | In Stock | £35.73 |
StarTech.com USB-C Multiport Adapter, HDMI | In Stock | £30.40 |
StarTech.com USB-C Triple Monitor Docking Station | In Stock | £180.53 |
StarTech.com USB-C Multiport Adapter - HDMI/DP | In Stock | £74.24 |
StarTech.com USB-C Multiport Adapter - HDMI/VGA | In Stock | £33.39 |
StarTech.com USB-C Speakerphone Dock | In Stock | £96.47 |
StarTech.com USB-C/USB-A Multiport Adapter | In Stock | £51.75 |
