Brand
StarTech.com USB-C to HDMI Adapter - 4K 60Hz
Quicklinx: C9J3WS00 Mfr#: CDP2HD4K60
Connect your MacBook, Chromebook or other USB Type-C laptop to an Ultra HD 60Hz display or projector. This USB-C to HDMI adapter lets you output HDMI video and audio from a USB Type-C device, such as a USB-C equipped MacBook, with support for Ultra HD 4K at 60 Hz. This adapter works with USB-C devices that pass a DisplayPort video signal, and it's also compatible with Thunderbolt 3 ports.
The adapter lets you harness the video capabilities that are built into your USB Type-C connection, to deliver the astonishing quality of UHD to your 4K 60 Hz display. This makes it easier for you to multitask, while working on the most resource-demanding applications imaginable. With this adapter, you can achieve an output resolution of up to 3840 x 2160p at 60 Hz, which is perfect for performing high-resolution tasks such as viewing 4K video. Plus, the adapter is backward compatible with 1080p displays, which makes it a great accessory for home, office or other workspace applications.
This USB type-C video adapter is highly portable, with a small footprint and a lightweight design. The adapter is the perfect accessory for your new slim USB-C device, fitting easily into your laptop bag or carrying case, which is great for BYOD (Bring Your Own Device) applications at the office.
This adapter lets you utilize the versatile USB Type-C port on your portable device. USB Type-C is a reversible connector, so it doesn't matter which way you plug it in. The reversible connector means you will always plug it in correctly on your first try, saving you the hassle and distraction of repeatedly attempting to connect your laptop to a display or projector, while you're delivering a presentation or speaking to a group.
  • Astonishing Picture Quality
  • Ultimate Portability
    This USB Type-C video adapter is highly portable, with a small footprint and a lightweight design. The adapter is the perfect accessory for your new slim USB-C device, fitting easily into your laptop bag or carrying case, which is great for BYOD (Bring Your Own Device) applications at the office.
  • Hassle-Free Connection with USB Type-C
    This adapter lets you utilize the versatile USB Type-C port on your portable device. USB Type-C is a reversible connector, so it doesn't matter which way you plug it in. The reversible connector means you will always plug it in correctly on your first try, saving you the hassle and distraction of repeatedly attempting to connect your laptop to a display or projector, while you're delivering a presentation or speaking to a group. The CDP2HD4K60 is backed by a 3-year StarTech.com warranty and free lifetime technical support. Note:
StarTech.com USB-C to HDMI Adapter - USB Type-C to HDMI Converter - 4K 60Hz - external video adapter - black
External video adapter
Bus Type
USB-C
Max Resolution
3840 x 2160
HDMI
2.5 cm 1.1 cm
Length
15 cm
Enclosure Colour
3-year warranty
P/N: TB3DK2DPM2, TB3DOCK2DPPD, TB3DOCK2DPPU, TB4CDOCK
Bus Type
USB-C
Max Resolution
3840 x 2160
HDMI
FCC, RoHS
2.5 cm
1.1 cm
Length
15 cm
23 g
Enclosure Colour
Limited warranty - 3 years
5 °C
35 °C
25 - 85% (non-condensing)
C9J3 StarTech.com USB-C to VGA Adapter In Stock £24.73
C9J3 StarTech.com USB-C to HDMI Adapter In Stock £19.98
C9J3 StarTech.com USB-C to HDMI Adapter In Stock £22.82
C9J3 StarTech.com USB-C to DisplayPort Adapter Cable 1m (3 ft.) - 4K at 60 Hz In Stock £29.49
C9J3 StarTech.com 6ft USB-C to DisplayPort Cable In Stock £27.71
C9J3 StarTech.com 2m USB-C to DVI Cable In Stock £25.59
C9J3 StarTech.com 2m USB-C to HDMI Cable In Stock £28.60
C9J3 StarTech.com 1m 3ft Premium HDMI 2.0 Cable In Stock £9.89
C9J3 StarTech.com 2m 6ft Premium HDMI 2.0 Cable In Stock £13.38
C9J3 StarTech.com 3m 10ft Premium HDMI 2.0 Cable In Stock £19.32
C9J3 StarTech.com USB-C to HDMI Adapter - 4K60Hz In Stock £37.44
C9J3 StarTech.com 1m USB C to DP Cable - White In Stock £23.84
C9J3 StarTech.com 6 ft USB C to DP Cable - White In Stock £27.86
C9J3 StarTech.com 3m USB C to DisplayPort Cable - White In Stock £29.38
C9J3 StarTech.com 3m USB C to DisplayPort Cable - Black In Stock £29.08
C9J3 StarTech.com 1.8m 6 ft USB C to mDP Cable In Stock £28.42
C9J3 StarTech.com Mini DisplayPort Cable - 4K 60Hz - Black - 3 ft / 1m In Stock £34.11
C9J3 StarTech.com USB-C to HDMI Adapter with HDR - 4K 60Hz - Black - USB Type C to HDMI Converter In Stock £40.19
C9J3 StarTech.com 5.9 ft (1.8 m) - USB-C to DisplayPort Adapter Cable In Stock £28.61
C9J3 StarTech.com 3.3 ft. (1 m) - USB-C to DisplayPort Adapter Cable - 8K In Stock £26.91
C9J3 StarTech.com USB C to DisplayPort Adapter - Power Delivery - 8K 30Hz In Stock £29.44
C9J3 StarTech.com 3ft (1m) USB C to HDMI Cable 4K 60Hz /HDR10 - USB-C to HDMI In Stock £15.86
C9J3 StarTech.com 6ft (2m) USB C to HDMI Cable 4K 60Hz / HDR10 - USB-C to HDMI In Stock £16.94
C9J3 StarTech.com 9.8ft (3m) USBC to HDMI Cable 4K USB-C HDMI Media Convertor In Stock £29.65
C9J3 StarTech.com 13ft (4m) USB C to HDMI Cable 4K HDMI USB-C to HDMI Monitor In Stock £31.46
C9J3 StarTech.com 16ft (5m) USB C to HDMI Cable 4K USB-C to HDMI Monitor Conve In Stock £36.65
C9J3 StarTech.com USB C to mDP Adapter 12" Cable In Stock £20.73
C9J3 StarTech.com USB C to HDMI Adapter 4K 60Hz In Stock £16.61
