Quicklinx: C1B1WS00 Mfr#: CDP2DVI
More than 50 in stock
£19.17 ex VAT
£23.00 inc VAT
Connect your MacBook, Chromebook or laptop with USB-C to a DVI monitor or projector. This USB-C to DVI adapter lets you output DVI video from a USB Type-C device such as a MacBook, Chromebook or Dell XPS laptop. The adapter works with USB-C devices that pass a DisplayPort video signal and it's also compatible with Thunderbolt 3 ports.
This USB Type-C video adapter is highly portable, with a small footprint and a lightweight design. It's the perfect accessory for your MacBook or Chromebook, fitting easily into your laptop bag or carrying case, which is great for BYOD (Bring Your Own Device) applications at the office.
The adapter supports dual-link video resolutions up to 2560x1600. You'll be surprised at the picture quality the adapter provides, even when connected to a DVI monitor, projector or television. The adapter harnesses the video capabilities that are built into your USB Type-C connection, to deliver every detail in stunning resolution.
This adapter lets you enjoy the versatility of your portable device's USB-C port. USB Type-C is a reversible connector, so it doesn't matter which way you plug it in, the adapter will always work.
The CDP2DVI features a black housing that looks great with your ChromeBook Pixel.
Your USB-C equipped device must support video to work with this adapter. Some legacy DVI monitors may be limited to a resolution of 1920x1200 when used with this adapter.
  • Clutter-free installation
    At 2 m (6 ft.) in length, the adapter cable delivers a direct connection between your USB-C device and your DVI monitor. This means you don't have to use additional adapters or cabling, which helps ensure a tidy and professional installation.
  • Hassle-free connection with USB Type-C
    The USB-C to DVI adapter cable is easy to connect, through the versatility and convenience of the USB Type-C port on your device. USB-C is a reversible connector, so it doesn't matter which way you plug it in, the adapter will always connect. This saves you the frustration of trying to insert it correctly when you're docking your computer to your workstation or office hot desk.
  • Crystal-clear picture quality
    The adapter harnesses the video capabilities that are built into your USB Type-C connector to deliver video resolutions up to 2560x1600, providing full dual-link support for your high-resolution DVI monitors - great for multitasking on high-resolution DVI displays. The adapter is backward compatible with 1080p displays, which makes it a great accessory for home, office or other HD work environments.
StarTech.com USB C to DVI Adapter - USB Type-C to DVI Video Converter - external video adapter - black
External video adapter
Bus Type
USB-C
Max Resolution
1920 x 1200
DVI-I
Enclosure Colour
Bus Type
USB-C
Max Resolution
1920 x 1200
DVI-I
FCC, RoHS
Enclosure Colour
70 °C
5 - 95% (non-condensing)
Price Range Ex VAT: 0 - 50
