StarTech.com USB-C to DisplayPort Adapter
Quicklinx: CQSFWS00 Mfr#: CDP2DP
Colours:
More than 50 in stock
£17.72 ex VAT
£21.26 inc VAT
Connect your laptop with USB Type-C to a DisplayPort monitor or screen. This USB-C to DisplayPort adapter enables you to output DP video and audio from the USB Type-C port on your laptop or other device. The adapter works with USB-C devices that pass a DisplayPort (DP) video signal, such as your MacBook Pro, Chromebook or other USB-C laptop. This enables you to connect your DisplayPort display to your USB-C computer using a DisplayPort cable.
The adapter lets you harness the video capabilities that are built into your computer's USB Type-C connection, to deliver the astonishing quality of UHD to your 4K 60Hz display. This makes it easier for you to multitask while working on the most resource-demanding applications imaginable.
With this adapter, you can achieve an output resolution of up to 3840 x 2160p at 60Hz, which is perfect for performing high-resolution tasks such as viewing 4K video. Plus, the adapter is backward compatible with 1080p displays, which makes it a great accessory for home, office or other workspace applications.
This USB Type-C video adapter is highly portable with a small footprint and lightweight design that's easy to tuck into your laptop bag. The adapter is the perfect accessory for connecting your MacBook Pro or Dell XPS to a DisplayPort monitor or display in BYOD (Bring Your Own Device) applications at the office.
This adapter lets you utilize the versatile USB Type-C port on your portable device. USB Type-C is a reversible connector, so it doesn't matter which way you plug it in, the adapter will always work, saving you the hassle and embarrassment of adjusting your device when you're trying to deliver a presentation.
Your USB-C device must support DisplayPort over USB-C (DP alt mode) to work with this adapter. This adapter outputs a single-mode DisplayPort signal and will not work with additional video adapters such as DisplayPort to HDMI, DisplayPort to VGA or DisplayPort to DVI adapters.
StarTech.com USB C to DisplayPort Adapter - 4K 60Hz - White - USB 3.1 Type-C to DisplayPort Adapter - USB C Video Adapter (CDP2DPW) - external video adapter - black
External video adapter
Bus Type
USB-C
Max Resolution
3840 x 2160
DisplayPort
Enclosure Colour
3-year warranty
Bus Type
USB-C
Max Resolution
3840 x 2160 at 60 Hz
DisplayPort
USB powered, 7.1 channel surround sound ready, Thunderbolt 3 compatible
FCC, RoHS
Enclosure Colour
Limited warranty - 3 years
CQSF StarTech.com 6 ft Mini DisplayPort to DisplayPort 1.2 Adapter Cable M/M - DisplayPort 4k In Stock £7.40
CQSF StarTech.com 3 ft DisplayPort 1.2 Cable with Latches M/M – DisplayPort 4k In Stock £9.72
CQSF StarTech.com 1 ft Short DisplayPort 1.2 Cable with Latches M/M – DisplayPort 4k In Stock £10.20
CQSF StarTech.com 10 ft DisplayPort 1.2 Cable with Latches M/M – DisplayPort 4k In Stock £13.69
CQSF StarTech.com USB-C to VGA Adapter In Stock £23.65
CQSF StarTech.com USB-C to VGA Adapter - White In Stock £21.53
CQSF StarTech.com USB-C to HDMI Adapter In Stock £17.77
CQSF StarTech.com USB-C to DisplayPort Adapter In Stock £17.72
Price Range Ex VAT: 0 - 50
