StarTech.com USB-C to DisplayPort Adapter
Quicklinx: CQSFWS00 Mfr#: CDP2DP
Colours:
37 In Stock
£23.87 ex VAT
£28.64 inc VAT
Connect your laptop with USB Type-C to a DisplayPort monitor or screen. This USB-C to DisplayPort adapter enables you to output DP video and audio from the USB Type-C port on your laptop or other device. The adapter works with USB-C devices that pass a DisplayPort (DP) video signal, such as your MacBook Pro, Chromebook or other USB-C laptop. This enables you to connect your DisplayPort display to your USB-C computer using a DisplayPort cable.
The adapter lets you harness the video capabilities that are built into your computer's USB Type-C connection, to deliver the astonishing quality of UHD to your 4K 60Hz display. This makes it easier for you to multitask while working on the most resource-demanding applications imaginable.
With this adapter, you can achieve an output resolution of up to 3840 x 2160p at 60Hz, which is perfect for performing high-resolution tasks such as viewing 4K video. Plus, the adapter is backward compatible with 1080p displays, which makes it a great accessory for home, office or other workspace applications.
This USB Type-C video adapter is highly portable with a small footprint and lightweight design that's easy to tuck into your laptop bag. The adapter is the perfect accessory for connecting your MacBook Pro or Dell XPS to a DisplayPort monitor or display in BYOD (Bring Your Own Device) applications at the office.
This adapter lets you utilize the versatile USB Type-C port on your portable device. USB Type-C is a reversible connector, so it doesn't matter which way you plug it in, the adapter will always work, saving you the hassle and embarrassment of adjusting your device when you're trying to deliver a presentation.
Your USB-C device must support DisplayPort over USB-C (DP alt mode) to work with this adapter. This adapter outputs a single-mode DisplayPort signal and will not work with additional video adapters such as DisplayPort to HDMI, DisplayPort to VGA or DisplayPort to DVI adapters.
  • Ultra HD 4K & 8K Resolution
    The adapter lets you harness the video capabilities that are built into your computer's USB Type-C connection, to deliver the astonishing quality of UHD to your 4K 60Hz display. This makes it easier for you to multitask while working on the most resource-demanding applications imaginable. With this adapter, you can also achieve an output resolution of up to 7680x4320 at 30Hz, which is perfect for performing high-resolution tasks such as viewing 8K video. Plus, the DP 1.4 adapter is backward compatible with 1080p displays, which makes it a great accessory for home, office or other workspace applications while future-proofing for 8K implementation.
  • Ultimate Portability
  • Hassle-Free Connection with USB Type-C
    This adapter lets you utilize the versatile USB Type-C port on your portable device. USB Type-C is a reversible connector, so it doesn't matter which way you plug it in, the adapter will always work, saving you the hassle and embarrassment of adjusting your device when you're trying to deliver a presentation. The CDP2DP is backed by a 3-year StarTech.com warranty and free lifetime technical support. Notes:
StarTech.com USB C to DisplayPort Adapter 4K 60Hz - USB Type-C to DP 1.4 Monitor Video Converter (DP Alt Mode) - Thunderbolt 3 Compatible - DisplayPort adapter - 24 pin USB-C to DisplayPort - 14 cm
DisplayPort adapter
8K30Hz (7680 x 4320) support, 4K60Hz support, HBR2 support, DisplayPort Alternate Mode support, 7.1 audio channel support, 32.4 Gbps data rate, Display Stream Compression (DSC)
Length
14 cm
Connector
24 pin USB-C - male (input)
Connector (Second End)
20 pin DisplayPort - female (output)
Thunderbolt 3 / DisplayPort 1.4
3-year warranty
P/N: BNDTB10GI, BNDTB1394B3, BNDTB210GSFP, BNDTB310GNDP, BNDTB410GSFP, BNDTB4M2E1, BNDTBUSB3142, TB31PCIEX16, TB33A1C, TB4CDOCK
DisplayPort adapter
Length
14 cm
3.7 cm
1.8 cm
1.4 cm
17 g
Connector
Thunderbolt 3 / DisplayPort 1.4, Plug and Play, FCC, RoHS, HDCP 2.2, HDCP 1.4
Shipping Width
12.5 cm
Shipping Depth
22.5 cm
Shipping Height
1.6 cm
Shipping Weight
26 g
3-year warranty
CQSF StarTech.com 6 ft Mini DisplayPort to DisplayPort 1.2 Adapter Cable M/M - DisplayPort 4k In Stock £9.12
CQSF StarTech.com 10 ft DisplayPort 1.2 Cable with Latches M/M – DisplayPort 4k In Stock £14.12
CQSF StarTech.com USB-C to VGA Adapter In Stock £23.74
CQSF StarTech.com USB-C to VGA Adapter - White In Stock £21.61
CQSF StarTech.com USB-C to HDMI Adapter In Stock £22.02
CQSF StarTech.com USB-C to HDMI Adapter In Stock £22.69
CQSF StarTech.com USB-C to DisplayPort Adapter Cable 1m (3 ft.) - 4K at 60 Hz In Stock £32.27
CQSF StarTech.com 6ft USB-C to DisplayPort Cable In Stock £28.80
CQSF StarTech.com 2m USB-C to HDMI Cable In Stock £31.44
CQSF StarTech.com USB-C to VGA - Power Delivery In Stock £23.19
CQSF StarTech.com USB-C to HDMI - Power Delivery In Stock £25.73
CQSF StarTech.com USB-C to DisplayPort Adapter In Stock £23.87
CQSF StarTech.com USB-C to DisplayPort Adapter In Stock £23.09
CQSF StarTech.com USB-C to DVI with USB PD In Stock £17.71
CQSF StarTech.com USB-C to DP with USB PD In Stock £31.36
CQSF StarTech.com 1m 3.3ft DisplayPort 1.4 Cable In Stock £13.68
CQSF StarTech.com 5.9 ft (1.8 m) - USB-C to DisplayPort Adapter Cable In Stock £18.36
CQSF StarTech.com 3.3 ft. (1 m) - USB-C to DisplayPort Adapter Cable - 8K In Stock £25.52
CQSF StarTech.com USB C to DisplayPort Adapter - 8K 30Hz - HBR3 Adapter In Stock £14.02
CQSF StarTech.com 3.3 ft. (1 m)?USB C to DisplayPort 1.4 Cable? In Stock £23.00
CQSF StarTech.com 6.6?ft.?(2 m)?USB C to DisplayPort 1.4 Cable In Stock £24.71
CQSF StarTech.com 3.3 ft. (1 m) USB C to DisplayPort 1.2 Cable In Stock £27.49
CQSF StarTech.com 6.6 ft. (2 m) USB C to DisplayPort 1.2 Cable In Stock £29.45
CQSF StarTech.com Portable USB C to HDMI Adapter with Keychain In Stock £18.81
CQSF StarTech.com Portable USB C to Mini DisplayPort Adapter w/ Keychain In Stock £11.28
CQSF StarTech.com Portable USB C to DisplayPort Adapter w/ Keychain - 4K In Stock £19.18
CQSF StarTech.com USB C to DisplayPort Adapter - Power Delivery - 8K 30Hz In Stock £32.41
CQSF StarTech.com 6 ft DisplayPort Cable with Latches - M/M In Stock £12.26
CQSF StarTech.com USB C to mDP Adapter 12" Cable In Stock £25.88
