StarTech.com USB C Multiport Video Adapter 4K/1080p - USB Type C to HDMI, VGA, DVI or Mini DisplayPort Monitor Adapter - Silver Aluminum - video interface converter - Mini DisplayPort / HDMI / DVI / VGA - 10.5 cm
Quicklinx: C5SGWS00 Mfr#: CDPVGDVHDMDP
Length: 10.5cm
34 in stock
£53.64 ex VAT
£64.36 inc VAT
Keep this compact adapter with your laptop while you're traveling, to connect to virtually any monitor, television or projector. This 4-in-1 travel adapter offers a portable solution for connecting your USB-C computer to a VGA, DVI, HDMI or Mini DisplayPort display.
The travel adapter is VESA certified to ensure compatibility with your DP alt mode computer. DP alt mode means your computer can pass a DisplayPort video signal through the USB-C port.
This travel adapter has been constructed with a sturdy aluminum housing and a built-in white USB-C cable. While the adapter looks great and works well with any device that supports DP alt mode, it's designed to seamlessly match your 2015 MacBook.
Instead of filling your laptop bag with different converters for different displays, this 4-in-1 adapter gives you all the video outputs you'll need. With VGA, DVI, HDMI and Mini DisplayPort outputs, this adapter lets you connect from your laptop's USB Type-C port to any boardroom or classroom display, without the inconvenience of carrying a separate adapter for each display type.
With support for multiple video outputs and a small-footprint design, this adapter is the ideal plug-and-play solution for travel or BYOD (Bring Your Own Device) applications around the office.
The adapter features a built-in magnetic fastener, for cable management. The magnet helps guide the breakout cable into place for quick and secure storage while traveling, ensuring the adapter is neatly stored in your travel bag.
The HDMI and Mini DisplayPort outputs on this travel adapter support Ultra HD 4K resolutions providing four times the picture quality of high-definition 1080p. The HDMI and mDP outputs are also backward compatible with lower resolutions, such as 1080p and 720p, so the adapter is also perfect for your legacy video equipment. The VGA and DVI outputs also support a high-definition maximum resolutions of up to 1920 x 1200 so you can still enjoy excellent video quality.
The travel adapter is compatible with USB Type C Intel Thunderbolt 3 devices that are capable of outputting a DisplayPort signal.
  • All-in-one video connectivity with travel in mind
    Avoid the hassle of carrying different adapters for different displays with this 4-in-1 USB-C adapter. With VGA, DVI, HDMI and mDP output, you can connect your laptop to virtually any display, a convenient plug-and-play solution for travel or Bring Your Own Device (BYOD) applications.
  • Astonishing picture quality
    The HDMI and mDP outputs on this USB-C video adapter support UHD 4K resolutions, providing four times the picture quality of high-definition 1080p. All of the outputs can support high-definition resolutions of up to 1920 x 1200.
  • Stylish connectivity
    The USB Type-C adapter has an aluminum housing designed to match your MacBook and is compatible with any device that supports USB-C DP Alt Mode. Featuring a built-in USB-C cable with magnetic cable manager, the USB-C video adapter conveniently stores away for easy travel.
Cable
Video interface converter - Mini DisplayPort / HDMI / DVI / VGA
Max Output Resolution
3840 x 2160 - 60 Hz
Length
10.5 cm
Silver
Connectors
USB-C - male (input)
Connectors (Second End)
HD-15 (VGA) - female , HDMI - female , DVI-D - female , Mini DisplayPort - female
DisplayPort 1.2
4K support, active adapter
3-year warranty
Cable Type
Video interface converter - 4K support, active
Interface Supported
Jacket Material
Plastic
DisplayPort 1.2
Length
10.5 cm
Aluminium casing, DisplayPort Alternate Mode support, 7.1 PCM audio channel support
Silver
Adapters & Converters
3840 x 2160
Refresh Rate
60 Hz
Connectors
24 pin USB-C - male (input)
15 pin HD D-Sub (HD-15) - female , 19 pin HDMI Type A - female , 24+1 pin digital DVI - female , Mini DisplayPort - female
FCC, RoHS, WEEE, REACH, RCM
5.5 cm
1.5 cm
108 g
Shipping Width
14.5 cm
Shipping Depth
17 cm
Shipping Height
3 cm
Shipping Weight
184 g
Limited warranty - 3 years
C5SG StarTech.com 6 ft DVI-D Dual Link Cable - M/M In Stock £6.71
C5SG StarTech.com 10 ft DVI-D Dual Link Cable - M/M In Stock £10.72
C5SG StarTech.com 3 ft Mini DisplayPort 1.2 Cable M/M - Mini DisplayPort 4k In Stock £10.08
C5SG StarTech.com 1 ft DVI-D Dual Link Cable - M/M In Stock £6.03
C5SG StarTech.com Mini DisplayPort to DisplayPort / DVI / HDMI Adapter – 3-in-1 mDP Converter In Stock £19.10
C5SG StarTech.com 3m High Speed HDMI Cable - Ultra HD 4k x 2k HDMI Cable - HDMI to HDMI M/M In Stock £9.68
C5SG StarTech.com 2m High Speed HDMI Cable – Ultra HD 4k x 2k HDMI Cable – HDMI to HDMI M/M In Stock £6.22
C5SG StarTech.com 1m High Speed HDMI Cable – Ultra HD 4k x 2k HDMI Cable – HDMI to HDMI M/M In Stock £5.14
C5SG StarTech.com 10m (33 ft) Active CL2 In-wall High Speed HDMI Cable - Ultra HD 4k x 2k HDMI Cable In Stock £50.52
C5SG StarTech.com Travel A/V Adapter: 3-in-1 mDP to VGA / DVI / HDMI Converter In Stock £33.01
C5SG StarTech.com Travel A/V Adapter: 3-in-1 Mini DisplayPort to VGA DVI or HDMI In Stock £33.01
C5SG StarTech.com mDP to HDMI or VGA Converter In Stock £18.11
C5SG StarTech.com USB C Multiport Video Adapter 4K/1080p - USB Type C to HDMI, VGA, DVI or Mini DisplayPort Monitor Adapter - Silver Aluminum - video interface converter - Mini DisplayPort / HDMI / DVI / VGA - 10.5 cm In Stock £53.64
C5SG StarTech.com mini DisplayPort to VGA DVI or HDMI Adapter In Stock £41.48
C5SG StarTech.com USB C Multiport Video Adapter - Rose Gold In Stock £44.73
C5SG StarTech.com USB C Multiport Video Adapter - Space Gray In Stock £55.05
Length: 10.5cm
Price Range Ex VAT: 50 - 100
