StarTech.com USB C Multiport Video Adapter - VGA or DisplayPort - HDR 4K60 - Display Adapter
Quicklinx: FVKSWS00 Mfr#: CDP2DPVGA
Length: 6.2cm
Hurry, only 1 left in stock!
£16.89 ex VAT
£20.26 inc VAT
High Dynamic Range Aluminum 6" (15.24 cm) Built-In Cable. This USB-C multiport video adapter offers a portable solution for connecting your USB Type-C laptop to a DisplayPort or VGA display. The adapter supports High Dynamic Range (HDR) and provides sharper images with enhanced video.
Two-in-One Video Connectivity with Travel in Mind
Avoid the hassle of carrying different adapters, with a 2-in-1 USB-C monitor adapter. Featuring both DisplayPort and VGA outputs, you can conveniently connect your laptop to any DP or VGA-equipped display, using this multiport adapter.
The adapter features a durable aluminum enclosure and can withstand being carried in your travel bag.
Astonishing 4K Picture Quality and HDR
The DisplayPort output on this USB-C video adapter lets you harness the audio and video capabilities that are built into your computer's USB-C connection, delivering the astonishing quality of UHD to your 4K 60Hz display. Plus, the VGA output supports HD resolutions up to 1920 x 1080, ensuring you won't have to sacrifice picture quality when connected to a VGA monitor or projector.
With HDR support, you can enjoy lifelike images with increased contrast, brightness and colors and greater luminosity than standard digital imaging.
Stylish Connectivity for Your MacBook, MacBook Pro, or Any Laptop
The USB-C display adapter has a Space Gray housing and built-in USB-C cable designed to match your Space Gray MacBook or MacBook Pro. The adapter is compatible with USB-C DP Alt Mode devices.
CDP2DPVGA is backed by a 3-year StarTech.com warranty and free lifetime technical support.
Note: This adapter only supports a single display - you are not able to output DisplayPort and VGA video simultaneously.
  • Two-in-one video connectivity with travel in mind
    Avoid the hassle of carrying different adapters, with a?2-in-1?USB-C monitor adapter.?Featuring both?DisplayPort and VGA?outputs, you can conveniently connect your laptop to any?DP?or VGA-equipped?display, using this?multiport?adapter.?? The?adapter?features a durable aluminum enclosure and can withstand being carried in your travel bag.
  • Astonishing 4K picture quality?and HDR
    The?DisplayPort?output on this?USB-C video?adapter?lets you harness the audio and?video?capabilities that are built into your computer's?USB-C?connection,?delivering?the astonishing quality of UHD to your?4K 60Hz?display.?Plus, the?VGA?output supports HD resolutions up to 1920?x?1080, ensuring you won't have to sacrifice picture quality when connected to a?VGA monitor?or projector.? With HDR support, you can enjoy lifelike images with increased contrast, brightness and colors and greater luminosity than standard digital imaging.
  • Stylish connectivity for your MacBook, MacBook Pro, or any laptop
    The?USB-C display adapter?has a Space Gray housing and built-in?USB-C?cable designed to match your Space Gray MacBook or MacBook Pro. The?adapter?is compatible with?USB-C DP?Alt Mode devices.
StarTech.com USB C Multiport Video Adapter, USB-C to 4K 60Hz DisplayPort 1.2 or 1080p VGA Monitor Adapter, USB Type-C 2-in-1 DP (HBR2 HDR)/VGA Display Converter- Thunderbolt 3 Compatible - USB-C 2 in 1 Adapter (CDP2DPVGA) - video adapter - 6.2 cm
Video adapter
4K support, HBR2 support, DisplayPort Alternate Mode support, HDR support
Length
6.2 cm
Connectors
24 pin USB-C - male
Connectors (Second End)
15 pin HD D-Sub (HD-15) - female , 20 pin DisplayPort - female
Displayport 1.2/Thunderbolt 3
Space grey
3-year warranty
Video adapter
Length
6.2 cm
Space grey
4.4 cm
1.5 cm
50 g
Connectors
24 pin USB-C - male
Displayport 1.2/Thunderbolt 3, FCC, RoHS, WEEE, REACH, RCM, HDCP 2.2, HDCP 1.4
Shipping Width
8 cm
Shipping Depth
17.8 cm
Shipping Height
2 cm
Shipping Weight
72 g
3-year warranty
FVKS StarTech.com 10 ft DisplayPort 1.2 Cable with Latches M/M – DisplayPort 4k In Stock £14.12
FVKS StarTech.com 1m 3.3ft DisplayPort 1.4 Cable In Stock £13.68
FVKS StarTech.com 3m 9.8ft DisplayPort 1.4 Cable In Stock £29.40
FVKS StarTech.com 6 ft DisplayPort Cable with Latches - M/M In Stock £12.26
FVKS StarTech.com USB C Multiport Video Adapter - VGA or Mini DisplayPort - HD In Stock £22.45
Length: 6.2cm
