StarTech.com USB C Multiport Video Adapter - Space Gray
Quicklinx: DXFTWS00 Mfr#: CDPVDHDMDPSG
Device Type: Laptop
Type: Docking
Device Screen Size: [N/A]
Colour: Space grey
£39.44 ex VAT
£47.32 inc VAT
Connect your laptop to an mDP, VGA or HDMI display with this space gray USB-C adapter. This USB-C multiport video adapter offers a portable solution for connecting your USB Type-C or Thunderbolt 3 computer to a VGA, DVI, HDMI or Mini DisplayPort display.
Avoid the hassle of carrying different adapters for different displays with this 4-in-1 USB-C video adapter'. With VGA, DVI, HDMI and mDP output, you can connect your laptop to virtually any display. It's a convenient plug-and-play solution for travel or Bring Your Own Device (BYOD) applications, wherever you go.
The adapter features a built-in magnetic fastener that helps guide the breakout cable into place for quick and secure portability. With its durable aluminum enclosure, the adapter can withstand being carried around in any travel bag.
The HDMI and mDP outputs on this adapter support UHD 4K resolutions providing four times the picture quality of high-definition 1080p. All of the outputs (HDMI, mDP, VGA, DVI) can support high-definition resolutions of up to 1920 x 1200.
This USB-C adapter has an aluminum housing and built-in black USB-C cable designed to match your space gray MacBook. The adapter is compatible with any device that supports USB-C DP Alt Mode.
StarTech.com USB C Multiport Video Adapter with HDMI, VGA, Mini DisplayPort or DVI, USB Type C Monitor Adapter to HDMI 1.4 or mDP 1.2 (4K), VGA or DVI (1080p), Space Gray Aluminum Adapter - 4-in-1 USB-C Converter (CDPVDHDMDPSG) - external video adapter - space grey
External video adapter
Bus Type
USB-C
Max Resolution
3840 x 2160
HDMI output (female connector) , VGA (female connector) , Mini DisplayPort (female connector) , DVI-D (female connector)
5.4 cm 1.5 cm
Length
10.4 cm
Enclosure Colour
Space grey
3-year warranty
Bus Type
USB-C
Max Resolution
3840 x 2160
HD/4k Ready, 7.1 channel surround sound ready
1 x USB-C cable - 11.5 cm
FCC, RoHS, WEEE, DisplayPort 1.2
5.4 cm
1.5 cm
Length
10.4 cm
90 g
Shipping Weight
100 g
Enclosure Colour
Space grey
Limited warranty - 3 years
DXFT StarTech.com 6 ft Mini DisplayPort to DisplayPort 1.2 Adapter Cable M/M - DisplayPort 4k In Stock £9.05
DXFT StarTech.com Mini DisplayPort to DisplayPort / DVI / HDMI Adapter – 3-in-1 mDP Converter In Stock £22.89
DXFT StarTech.com 1m (3 ft) White Mini DisplayPort to DisplayPort 1.2 Adapter Cable M/M - DisplayPort 4k In Stock £10.43
DXFT StarTech.com 2m (6 ft) White Mini DisplayPort to DisplayPort 1.2 Adapter Cable M/M - DisplayPort 4k In Stock £12.60
DXFT StarTech.com 3m (10 ft) White Mini DisplayPort to DisplayPort 1.2 Adapter Cable M/M - DisplayPort 4k In Stock £15.35
DXFT StarTech.com 1m (3 ft) White Mini DisplayPort 1.2 Cable M/M - Mini DisplayPort 4k In Stock £14.48
DXFT StarTech.com 2m (6 ft) White Mini DisplayPort 1.2 Cable M/M - Mini DisplayPort 4k In Stock £16.38
DXFT StarTech.com 3m (10 ft) White Mini DisplayPort Cable - M/M In Stock £17.45
DXFT StarTech.com 4m Mini DisplayPort to DisplayPort Adapter Cable - M/M In Stock £21.60
DXFT StarTech.com Travel A/V Adapter: 3-in-1 mDP to VGA / DVI / HDMI Converter In Stock £25.48
DXFT StarTech.com Travel A/V Adapter: 3-in-1 Mini DisplayPort to VGA DVI or HDMI In Stock £23.91
DXFT StarTech.com mDP to HDMI or VGA Converter In Stock £19.89
DXFT StarTech.com USB C Multiport Video Adapter with HDMI, VGA, Mini DisplayPort or DVI, USB Type C Monitor Adapter to HDMI 1.4 or mDP 1.2 (4K), VGA or DVI (1080p), Silver Aluminum Adapter - 4-in-1 USB-C Converter (CDPVGDVHDMDP) - adapter - Mini DisplayPort / HDMI / DVI / VGA - 10.5 cm In Stock £59.56
DXFT StarTech.com USB C Multiport Video Adapter - Rose Gold In Stock £48.81
DXFT StarTech.com USB C Multiport Video Adapter - Space Gray In Stock £39.44
DXFT StarTech.com USB-C Multiport Video Adapter 4-in-1 - 95W Power Delivery - Space Gray - 4K 60Hz In Stock £64.19
DXFT StarTech.com USB C to VGA and HDMI Adapter - Aluminum - USB-C Multiport Adapter - 6" Built-In Cable In Stock £32.60
DXFT StarTech.com USB-C to HDMI Adapter with HDR - 4K 60Hz - Black - USB Type C to HDMI Converter In Stock £19.81
DXFT StarTech.com USB C Multiport Video Adapter - VGA or Mini DisplayPort - HD In Stock £22.45
DXFT StarTech.com USB C Multiport Video Adapter - HDMI or DisplayPort - HDR 4K60 - Display Adapter In Stock £33.34
DXFT StarTech.com USB C Multiport Video Adapter - VGA or DisplayPort - HDR 4K60 - Display Adapter In Stock £16.75
DXFT StarTech.com USB C Multiport Video Adapter - HDMI or Mini DisplayPort -HDR 4K Display Adapter In Stock £32.99
DXFT StarTech.com USB C to HDMI Adapter 4K 60Hz In Stock £19.65
Device Type: Laptop
Type: Docking
Colour: Space grey
