Connect your laptop to an mDP, VGA or HDMI display with this space gray USB-C adapter. This USB-C multiport video adapter offers a portable solution for connecting your USB Type-C or Thunderbolt 3 computer to a VGA, DVI, HDMI or Mini DisplayPort display.
Avoid the hassle of carrying different adapters for different displays with this 4-in-1 USB-C video adapter'. With VGA, DVI, HDMI and mDP output, you can connect your laptop to virtually any display. It's a convenient plug-and-play solution for travel or Bring Your Own Device (BYOD) applications, wherever you go.
The adapter features a built-in magnetic fastener that helps guide the breakout cable into place for quick and secure portability. With its durable aluminum enclosure, the adapter can withstand being carried around in any travel bag.
The HDMI and mDP outputs on this adapter support UHD 4K resolutions providing four times the picture quality of high-definition 1080p. All of the outputs (HDMI, mDP, VGA, DVI) can support high-definition resolutions of up to 1920 x 1200.
This USB-C adapter has an aluminum housing and built-in black USB-C cable designed to match your space gray MacBook. The adapter is compatible with any device that supports USB-C DP Alt Mode.
- StarTech.com USB C Multiport Video Adapter with HDMI, VGA, Mini DisplayPort or DVI, USB Type C Monitor Adapter to HDMI 1.4 or mDP 1.2 (4K), VGA or DVI (1080p), Space Gray Aluminum Adapter - 4-in-1 USB-C Converter (CDPVDHDMDPSG) - external video adapter - space grey
- External video adapter
- Bus Type
- USB-C
- Max Resolution
- 3840 x 2160
- HDMI output (female connector) , VGA (female connector) , Mini DisplayPort (female connector) , DVI-D (female connector)
- 5.4 cm 1.5 cm
- Length
- 10.4 cm
- Enclosure Colour
- Space grey
- 3-year warranty
- Bus Type
- USB-C
- Max Resolution
- 3840 x 2160
- HD/4k Ready, 7.1 channel surround sound ready
- Cables Included
- 1 x USB-C cable - 11.5 cm
- FCC, RoHS, WEEE, DisplayPort 1.2
- 5.4 cm
- 1.5 cm
- Length
- 10.4 cm
- 90 g
- Shipping Weight
- 100 g
- Enclosure Colour
- Space grey
- Limited warranty - 3 years
StarTech.com 6 ft Mini DisplayPort to DisplayPort 1.2 Adapter Cable M/M - DisplayPort 4k | In Stock | £9.12 |
StarTech.com Mini DisplayPort to DisplayPort / DVI / HDMI Adapter – 3-in-1 mDP Converter | In Stock | £22.89 |
StarTech.com 1m (3 ft) White Mini DisplayPort to DisplayPort 1.2 Adapter Cable M/M - DisplayPort 4k | In Stock | £10.43 |
StarTech.com 2m (6 ft) White Mini DisplayPort to DisplayPort 1.2 Adapter Cable M/M - DisplayPort 4k | In Stock | £12.60 |
StarTech.com 3m (10 ft) White Mini DisplayPort to DisplayPort 1.2 Adapter Cable M/M - DisplayPort 4k | In Stock | £15.35 |
StarTech.com 1m (3 ft) White Mini DisplayPort 1.2 Cable M/M - Mini DisplayPort 4k | In Stock | £14.48 |
StarTech.com 2m (6 ft) White Mini DisplayPort 1.2 Cable M/M - Mini DisplayPort 4k | In Stock | £16.38 |
StarTech.com 3m (10 ft) White Mini DisplayPort Cable - M/M | In Stock | £17.45 |
StarTech.com 4m Mini DisplayPort to DisplayPort Adapter Cable - M/M | In Stock | £21.60 |
StarTech.com Travel A/V Adapter: 3-in-1 mDP to VGA / DVI / HDMI Converter | In Stock | £25.48 |
StarTech.com Travel A/V Adapter: 3-in-1 Mini DisplayPort to VGA DVI or HDMI | In Stock | £23.91 |
StarTech.com mDP to HDMI or VGA Converter | In Stock | £19.89 |
StarTech.com USB C Multiport Video Adapter - Rose Gold | In Stock | £48.81 |
StarTech.com USB C Multiport Video Adapter - Space Gray | In Stock | £39.44 |
StarTech.com USB-C Multiport Video Adapter 4-in-1 - 95W Power Delivery - Space Gray - 4K 60Hz | In Stock | £64.19 |
StarTech.com USB C to VGA and HDMI Adapter - Aluminum - USB-C Multiport Adapter - 6" Built-In Cable | In Stock | £32.60 |
StarTech.com USB-C to HDMI Adapter with HDR - 4K 60Hz - Black - USB Type C to HDMI Converter | In Stock | £19.81 |
StarTech.com USB C Multiport Video Adapter - VGA or Mini DisplayPort - HD | In Stock | £22.45 |
StarTech.com USB C Multiport Video Adapter - HDMI or DisplayPort - HDR 4K60 - Display Adapter | In Stock | £33.34 |
StarTech.com USB C Multiport Video Adapter - VGA or DisplayPort - HDR 4K60 - Display Adapter | In Stock | £16.89 |
StarTech.com USB C Multiport Video Adapter - HDMI or Mini DisplayPort -HDR 4K Display Adapter | In Stock | £32.99 |
StarTech.com USB C to HDMI Adapter 4K 60Hz | In Stock | £19.65 |
