StarTech.com USB C Multiport Video Adapter - Rose Gold
Quicklinx: DXFSWS00 Mfr#: CDPVDHDMDPRG
Device Type: Laptop
Type: Docking
Device Screen Size: [N/A]
Colour: Rose gold
Hurry, only 1 left in stock!
£48.81 ex VAT
£58.57 inc VAT
This USB-C multiport video adapter offers a portable solution for connecting your USB Type-C or Thunderbolt 3 computer to a VGA, DVI, HDMI or Mini DisplayPort display.
Avoid the hassle of carrying different adapters for different displays with this 4-in-1 USB-C video adapter'. With VGA, DVI, HDMI and mDP output, you can connect your laptop to virtually any display. It's a convenient plug-and-play solution for travel or Bring Your Own Device (BYOD) applications, wherever you go.
The adapter features a built-in magnetic fastener that helps guide the breakout cable into place for quick and secure portability. With its durable aluminum enclosure, the adapter can withstand being carried around in any travel bag.
The HDMI and mDP outputs on this adapter support UHD 4K resolutions providing four times the picture quality of high-definition 1080p. All of the outputs (HDMI, mDP, VGA, DVI) can support high-definition resolutions of up to 1920 x 1200.
This USB-C adapter has an aluminum housing and built-in white USB-C cable designed to match your rose gold MacBook. The adapter is compatible with any device that supports USB-C DP Alt Mode.
StarTech.com USB C Multiport Video Adapter with HDMI, VGA, Mini DisplayPort or DVI, USB Type C Monitor Adapter to HDMI 1.4 or mDP 1.2 (4K), VGA or DVI (1080p), Rose Gold Aluminum Adapter - 4-in-1 USB-C Converter (CDPVDHDMDPRG) - external video adapter - rose gold
External video adapter
Bus Type
USB-C
Max Resolution
3840 x 2160
HDMI output (female connector) , VGA (female connector) , Mini DisplayPort (female connector) , DVI-D (female connector)
5.4 cm 1.5 cm
Length
10.4 cm
Enclosure Colour
Rose gold
3-year warranty
Bus Type
USB-C
Max Resolution
3840 x 2160
HD/4k Ready, 7.1 channel surround sound ready
1 x USB-C cable - 11.5 cm
FCC, RoHS, WEEE, DisplayPort 1.2
5.4 cm
1.5 cm
Length
10.4 cm
90 g
Shipping Weight
100 g
Enclosure Colour
Rose gold
Limited warranty - 3 years
DXFS StarTech.com 6 ft Mini DisplayPort to DisplayPort 1.2 Adapter Cable M/M - DisplayPort 4k In Stock £9.12
DXFS StarTech.com Mini DisplayPort to DisplayPort / DVI / HDMI Adapter – 3-in-1 mDP Converter In Stock £22.89
DXFS StarTech.com 1m (3 ft) White Mini DisplayPort to DisplayPort 1.2 Adapter Cable M/M - DisplayPort 4k In Stock £10.43
DXFS StarTech.com 2m (6 ft) White Mini DisplayPort to DisplayPort 1.2 Adapter Cable M/M - DisplayPort 4k In Stock £12.74
DXFS StarTech.com 3m (10 ft) White Mini DisplayPort to DisplayPort 1.2 Adapter Cable M/M - DisplayPort 4k In Stock £15.35
DXFS StarTech.com 1m (3 ft) White Mini DisplayPort 1.2 Cable M/M - Mini DisplayPort 4k In Stock £14.48
DXFS StarTech.com 2m (6 ft) White Mini DisplayPort 1.2 Cable M/M - Mini DisplayPort 4k In Stock £16.38
DXFS StarTech.com 3m (10 ft) White Mini DisplayPort Cable - M/M In Stock £17.45
DXFS StarTech.com 4m Mini DisplayPort to DisplayPort Adapter Cable - M/M In Stock £21.60
DXFS StarTech.com Travel A/V Adapter: 3-in-1 mDP to VGA / DVI / HDMI Converter In Stock £25.48
DXFS StarTech.com Travel A/V Adapter: 3-in-1 Mini DisplayPort to VGA DVI or HDMI In Stock £23.91
DXFS StarTech.com mDP to HDMI or VGA Converter In Stock £19.89
DXFS StarTech.com USB C Multiport Video Adapter with HDMI, VGA, Mini DisplayPort or DVI, USB Type C Monitor Adapter to HDMI 1.4 or mDP 1.2 (4K), VGA or DVI (1080p), Silver Aluminum Adapter - 4-in-1 USB-C Converter (CDPVGDVHDMDP) - adapter - Mini DisplayPort / HDMI / DVI / VGA - 10.5 cm In Stock £59.56
DXFS StarTech.com USB C Multiport Video Adapter - Rose Gold In Stock £48.81
DXFS StarTech.com USB C Multiport Video Adapter - Space Gray In Stock £39.44
DXFS StarTech.com USB-C Multiport Video Adapter 4-in-1 - 95W Power Delivery - Space Gray - 4K 60Hz In Stock £64.19
DXFS StarTech.com USB C to VGA and HDMI Adapter - Aluminum - USB-C Multiport Adapter - 6" Built-In Cable In Stock £32.60
DXFS StarTech.com USB-C to HDMI Adapter with HDR - 4K 60Hz - Black - USB Type C to HDMI Converter In Stock £19.81
DXFS StarTech.com USB C Multiport Video Adapter - VGA or Mini DisplayPort - HD In Stock £22.45
DXFS StarTech.com USB C Multiport Video Adapter - HDMI or DisplayPort - HDR 4K60 - Display Adapter In Stock £33.34
DXFS StarTech.com USB C Multiport Video Adapter - VGA or DisplayPort - HDR 4K60 - Display Adapter In Stock £16.89
DXFS StarTech.com USB C Multiport Video Adapter - HDMI or Mini DisplayPort -HDR 4K Display Adapter In Stock £32.99
DXFS StarTech.com USB C to HDMI Adapter 4K 60Hz In Stock £19.65
Device Type: Laptop
Type: Docking
Colour: Rose gold
