StarTech.com USB C Multiport Video Adapter - Rose Gold
Quicklinx: DXFSWS00 Mfr#: CDPVDHDMDPRG
Type: Docking
Colour: Rose gold
15 in stock
£54.36 ex VAT
£65.23 inc VAT
This USB-C multiport video adapter offers a portable solution for connecting your USB Type-C or Thunderbolt 3 computer to a VGA, DVI, HDMI or Mini DisplayPort display.
Avoid the hassle of carrying different adapters for different displays with this 4-in-1 USB-C video adapter'. With VGA, DVI, HDMI and mDP output, you can connect your laptop to virtually any display. It's a convenient plug-and-play solution for travel or Bring Your Own Device (BYOD) applications, wherever you go.
The adapter features a built-in magnetic fastener that helps guide the breakout cable into place for quick and secure portability. With its durable aluminum enclosure, the adapter can withstand being carried around in any travel bag.
The HDMI and mDP outputs on this adapter support UHD 4K resolutions providing four times the picture quality of high-definition 1080p. All of the outputs (HDMI, mDP, VGA, DVI) can support high-definition resolutions of up to 1920 x 1200.
This USB-C adapter has an aluminum housing and built-in white USB-C cable designed to match your rose gold MacBook. The adapter is compatible with any device that supports USB-C DP Alt Mode.
StarTech.com USB-C Multiport Video Adapter - 4-in-1 USB-C Adapter Rose Gold - external video adapter - rose gold
External video adapter
Bus Type
USB-C
Max Resolution
3840 x 2160
HDMI output (female connector) , VGA (female connector) , Mini DisplayPort (female connector) , DVI-D (female connector)
5.4 cm 1.5 cm
Length
10.4 cm
Enclosure Colour
Rose gold
3-year warranty
Bus Type
USB-C
Max Resolution
3840 x 2160
HD/4k Ready, 7.1 channel surround sound ready
1 x USB-C cable - 11.5 cm
FCC, RoHS, WEEE, DisplayPort 1.2
5.4 cm
1.5 cm
Length
10.4 cm
90 g
Shipping Weight
100 g
Enclosure Colour
Rose gold
Limited warranty - 3 years
StarTech.com USB C Multiport Video Adapter - Rose Gold Bundle deal on StarTech.com USB C Multiport Video Adapter - Rose Gold
£153.53
DXFS StarTech.com Mini DisplayPort to DisplayPort / DVI / HDMI Adapter – 3-in-1 mDP Converter In Stock £18.91
DXFS StarTech.com Travel A/V Adapter: 3-in-1 mDP to VGA / DVI / HDMI Converter In Stock £32.61
DXFS StarTech.com Travel A/V Adapter: 3-in-1 Mini DisplayPort to VGA DVI or HDMI In Stock £32.61
DXFS StarTech.com mDP to HDMI or VGA Converter In Stock £17.92
DXFS StarTech.com USB C Multiport Video Adapter – Aluminum – USB-C to VGA/HDMI/Mini DisplayPort/DVI Adapter –Display Adapter (CDPVGDVHDMDP) - external video adapter In Stock £52.98
DXFS StarTech.com mini DisplayPort to VGA DVI or HDMI Adapter In Stock £40.96
DXFS StarTech.com USB C Multiport Video Adapter - Rose Gold In Stock £54.36
DXFS StarTech.com USB C Multiport Video Adapter - Space Gray In Stock £54.36
Type: Docking
Colour: Rose gold
Price Range Ex VAT: 50 - 100
