High Dynamic Range Aluminum 6" (15.24 cm) Built-In Cable. This USB-C multiport video adapter offers a portable solution for connecting your USB Type-C laptop to an HDMI or Mini DisplayPort display. The adapter supports High Dynamic Range (HDR) and provides sharper images with enhanced video.
Two-in-One Video Connectivity with Travel in Mind
Avoid the hassle of carrying different adapters, with a 2-in-1 USB-C monitor adapter. The mutliport adapter features both HDMI and Mini DP outputs, so you can conveniently connect your laptop to any HDMI or mDP-equipped display.
The adapter features a durable aluminum enclosure and can withstand being carried in your travel bag.
Astonishing 4K Picture Quality and HDR
The HDMI and Mini DisplayPort outputs on this USB-C video adapter lets you harness the audio and video capabilities that are built into your computer's USB-C connection, delivering the astonishing quality of UHD to your 4K 60Hz display. This makes it easier for you to multitask while working on the most resource-demanding applications imaginable.
With HDR support, you can enjoy lifelike images with increased contrast, brightness and colors and greater luminosity than standard digital imaging.
Stylish Connectivity for Your MacBook, MacBook Pro, or Any Laptop
The USB-C display adapter has a Space Gray housing and built-in USB-C cable designed to match your Space Gray MacBook or MacBook Pro. The adapter is compatible with USB-C DP Alt Mode devices.
CDP2HDMDP is backed by a 3-year StarTech.com warranty and free lifetime technical support.
Note: This adapter only supports a single display - you are not able to output Mini DisplayPort and HDMI video simultaneously.
Two-in-one video connectivity with travel in mind
Avoid the hassle of carrying different adapters, with a 2-in-1?USB-C monitor adapter.?The mutliport adapter features both?HDMI and Mini DP?outputs, so you can conveniently connect your laptop to any?HDMI or mDP-equipped display. The adapter features a durable aluminum enclosure and can withstand being carried in your travel bag. -
Astonishing picture quality?and HDR
The?HDMI and Mini DisplayPort?outputs on this?USB-C video?adapter?let you harness the audio and video capabilities that are built into your computer's?USB-C?connection,?delivering?the astonishing quality of 4K on your display. This makes it easier for you to multitask while working on resource-demanding applications imaginable.?With HDR support, you can enjoy lifelike images with increased contrast, brightness and colors and greater luminosity than standard digital imaging. -
Stylish connectivity
The USB-C display adapter has a sleek housing and built-in USB-C cable designed to match your devices.
- StarTech.com USB C Multiport Video Adapter, 4K 60Hz USB-C to HDMI 2.0 or Mini DisplayPort 1.2 Monitor Adapter, USB Type-C 2-in-1 Display Converter HDMI/MDP HBR2 HDR, Works w/ Thunderbolt 3 - USB-C 2 in 1 Adapter (CDP2HDMDP) - adapter - Mini DisplayPort / HDMI - 20.5 cm
- Cable
- Adapter - Mini DisplayPort / HDMI
- Max Output Resolution
- 3840 x 2160 - 60 Hz
- Length
- 20.5 cm
- Space grey
- Connectors
- 24 pin USB-C - male (input)
- Connectors (Second End)
- HDMI - female (output) , Mini DisplayPort - female (output)
- Displayport 1.2/Thunderbolt 3
- 4K support, active adapter
- 3-year warranty
- Cable Type
- Adapter 4K support, active
- Interface Supported
- Jacket Material
- Aluminium
- Length
- 20.5 cm
- HDR support, HBR2 audio support, multi-channel audio, DisplayPort Alternate Mode support, Realtek RTD2142S-CG chipset
- Space grey
Adapters & Converters
- 3840 x 2160
- Refresh Rate
- 60 Hz
- Connectors
- 19 pin HDMI Type A - female (output) , Mini DisplayPort - female (output)
- FCC, RoHS, WEEE, REACH, RCM
- 6.2 cm
- 1.5 cm
- 48 g
- Shipping Width
- 14.2 cm
- Shipping Depth
- 17 cm
- Shipping Height
- 3 cm
- Shipping Weight
- 70 g
- Limited warranty - 3 years
