StarTech.com USB-C Multiport Adapter Docking Station
Quicklinx: DV1LWS00 Mfr#: DK30C2HAGPD
Device Type: Laptop
Type: Docking Stations
Device Screen Size: [N/A]
Colour: Black
16 In Stock
£129.92 ex VAT
£155.90 inc VAT
This USB-C multiport adapter turns your Windows laptop into a portable workstation. The dual HDMI adapter connects your USB-C laptop to two HDMI monitors, letting you power through work faster or make presentations with different views on two displays. It gives you two USB-A ports, a Gigabit Ethernet port, a DP Alt Mode Switch, and laptop charging.
Through 100W Power Delivery 3.0, the USB Type-C multiport adapter powers itself as well as your laptop and any attached peripherals, with up to 85W laptop charging when connected to a USB-C power adapter. PD 3.0 features Fast Role Swap to prevent USB data disruption when you unplug the power adapter to switch power sources (USB-C power adapter to bus power).
The USB-C HDMI multiport adapter extends your laptop screen to dual HDMI displays. Using the DP Alt Mode switch, you can choose between higher display resolution or faster USB speed to meet your needs, for desktop or portable use. Choose between: dual 4K30 (or single 4K60) resolution with USB 2.0 speed, or dual 1080p (or single 4K30) resolution with USB 3.0 speed.
The USB-C display adapter gives you two USB-A ports (one USB 3.0/USB 2.0 port, and one USB 2.0) to connect your mouse, keyboard or other peripherals.
The GbE port ensures reliable wired network access. A 1 m USB-C cable is included for greater flexibility.
Note: To ensure full adapter functionality, your laptop's USB-C port must support USB Power Delivery and DP Alt Mode.
  • DisplayPort Alternate Mode to Choose Your Video Display Output
    Achieve dual 1080p up to a single 4K 60Hz display using the DisplayPort Alternate Mode (DP Alt-Mode) configuration switch.
  • Reliable 100W Power Delivery Passthrough
    The USB-C multiport adapter uses your USB-C laptop's power adapter and can provide up to 100W Power Delivery (3.0) pass through with up to 85W for your host device for charging. The remaining wattage will power the docking station along with any attached USB-A peripherals such as smartphones and tablets.
  • Multi-Stream Transport for Driverless Displays
    The multi-stream transport technology (MST) in this dock powers two HDMI monitors with no driver installation required so you are up and running faster.
    Developed to improve performance and security, StarTech.com Connectivity Tools is the only software suite on the market that works with a wide range of IT connectivity accessories. The software suite includes: •Text | Advanced Windows Layout Utility : To setup and save custom windows layouts. •Text | Mac Address Pass-Through Utility : To improve network security. •Text | USB Event Monitoring Utility : To track and log connected USB devices •Text | Wi-Fi Auto Switch Utility : Enabling users to quickly access faster network speeds via wired LAN. Our local StarTech.com Technical Advisors have broad product expertise and work directly with StarTech.com Engineers to provide support for our customers both pre and post-sales. This docking station is backed by a StarTech.com 3-Year warranty and free lifetime technical support.
StarTech.com USB C Dock, 4K Dual Monitor HDMI Display, Mini Laptop Docking Station, 100W Power Delivery Passthrough, GbE, 2-Port USB-A Hub, USB Type-C Multiport Adapter,3.3' Cable, Dual 4K - 4K Mini Laptop Dock (DK30C2HAGPD) - docking station - USB-C - 2 x HDMI - 1GbE
Docking station
Docking Interface
USB-C
Video Interfaces
2 x HDMI
6 cm x 12 cm x 1.88 cm
200 g
Gigabit Ethernet
3-year warranty
P/N: ARMBARDUO, ARMBARDUOV, ARMDUAL, ARMDUAL30, ARMDUALV, ARMSLIMDUO
Docking station
6 cm
12 cm
1.88 cm
200 g
Enclosure Colour
Gigabit Ethernet
IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, USB 1.1, USB 2.0, USB 3.0
1 x SuperSpeed USB 3.0 - 24 pin USB-C , 1 x USB-C with Power Delivery - 24 pin USB-C , 2 x display / video - HDMI output - 19 pin HDMI Type A , 1 x network - Ethernet 1000 - RJ-45 , 1 x SuperSpeed USB 3.0 - 9 pin USB Type A , 1 x USB - 4 pin USB Type A
1 x USB-C cable
USB powered, dual display support, 4K Ultra HD, 85W power delivery, auto MDIX support
FCC, RoHS, WEEE, UASP (USB Attached SCSI Protocol), USB Power Delivery 3.0
Apple MacOS X 10.9 - 10.12, Apple macOS 11.0, Apple macOS 10.14 - 10.15, Microsoft Windows 7 / 8 / 8.1 / 10 / 11, Apple macOS 12.0, Apple macOS 13.0
Limited warranty - 3 years
Shipping Weight
220 g
50 °C
DV1L StarTech.com Dual Monitor Mount - Articulating Arms - Grommet or Desk Mount In Stock £143.67
DV1L StarTech.com Monitor Mount - USB Passthrough In Stock £176.82
DV1L StarTech.com Dual Monitor Mount - Stackable In Stock £226.92
DV1L StarTech.com Dual Monitor Stand In Stock £91.00
DV1L StarTech.com USB-C Multifunction Adapter In Stock £55.99
DV1L StarTech.com USB-C to 4K HDMI Adapter with Power Delivery In Stock £50.91
DV1L StarTech.com USB-C to VGA Adapter with PD In Stock £41.47
DV1L StarTech.com Vertical Dual Monitor Stand In Stock £90.68
DV1L StarTech.com Vertical Dual Monitor Mount In Stock £76.91
DV1L StarTech.com 1m USB 3.1 C Cable w/ PD (5A) In Stock £26.96
DV1L StarTech.com USB-C Multiport Adapter - DVI In Stock £51.00
DV1L StarTech.com Thin Client Mount - VESA In Stock £26.25
DV1L StarTech.com 1.8m USB 3.1 5Gbps with PD (5A) C to C Cable - M/M Certified In Stock £24.40
DV1L StarTech.com 20" USB C Cable 10Gbps Gen2 In Stock £13.40
DV1L StarTech.com 6ft USB C Cable 5Gbps Gen1 In Stock £19.03
DV1L StarTech.com USB C Dock DP 4K30Hz or VGA In Stock £115.87
Device Type: Laptop
Colour: Black
