This USB-C multiport adapter turns your Windows laptop into a portable workstation. The USB-C to dual Display Port adapter connects your USB-C laptop to two DisplayPort monitors, letting you power through work faster or make presentations with different views on two displays. It gives you two USB-A ports, a Gigabit Ethernet port, a DP Alt Mode Switch, and laptop charging.
Through 100W?Power Delivery?3.0,?the?USB Type-C to DisplayPort adapter powers itself as well as your laptop and any attached peripherals, with up to 85W laptop charging when connected to a USB-C power adapter.?PD?3.0 features Fast Role Swap to prevent USB data disruption when?you?unplug?the power adapter to?switch?power sources (USB-C?power adapter to?bus power).
The USB-C video adapter extends your laptop screen to?dual DisplayPort displays. Using the DP Alt Mode switch, you can choose between higher display resolution or faster USB speed to meet your needs, for desktop or portable use. Choose between: dual 4K30 (or single 4K60) resolution with USB 2.0 speed, or dual 1080p (or single 4K30) resolution with USB 3.0 speed.
- StarTech.com USB C Dock, 4K Dual Monitor DisplayPort, Mini Laptop Docking Station, 100W Power Delivery Passthrough, GbE, 2-Port USB-A Hub, USB Type-C Multiport Adapter 3.3' Cable, Dual DP - Portable USB-C Dock (DK30C2DAGPD) - docking station - USB-C - 2 x DP - 1GbE
- Product Type
- Docking station
- Docking Interface
- USB-C
- Video Interfaces
- 2 x DP
- 6 cm x 12 cm x 1.18 cm
- 200 g
- Black
- Networking
- Gigabit Ethernet
- 3-year warranty
- Designed For
- P/N: ARMBARDUO, ARMBARDUOV, ARMDUAL, ARMDUAL30, ARMDUALV, ARMSLIMDUO
- Product Type
- Docking station
- 6 cm
- 12 cm
- 1.18 cm
- 200 g
- Enclosure Colour
- Black
Video
- Max Resolution Details
- 4096 x 2160 - 60 Hz
- Data Link Protocol
- IEEE 802.3, IEEE 802.3u, IEEE 802.3ab
- 1 x USB 3.1 Gen 1 - 24 pin USB-C , 1 x USB 3.1 Gen 1 with Power Delivery - 24 pin USB-C , 2 x display / video - 20 pin DisplayPort , 1 x network - 1000Base-T - RJ-45 , 1 x SuperSpeed USB 3.0 - 9 pin USB Type A , 1 x USB 2.0 - 4 pin USB Type A
- Cables Included
- 1 x USB-C cable - external - 1 m
- Dual monitor support, DisplayPort Alt Mode, 100W power delivery
- FCC, RoHS, UASP (USB Attached SCSI Protocol)
- OS Required
- Microsoft Windows 7 / 8 / 8.1 / 10
- Limited warranty - 3 years
- Shipping Weight
- 220 g
- 0 °C
- 50 °C
- Designed For
StarTech.com DisplayPort to VGA Video Adapter Converter | In Stock | £24.19 |
StarTech.com DisplayPort to VGA Video Adapter Converter | In Stock | £15.80 |
StarTech.com DisplayPort to DVI Active Adapter | In Stock | £22.91 |
StarTech.com 10m Active DisplayPort Cable - DP to DP M/M | In Stock | £91.66 |
StarTech.com Dual Monitor Mount - Articulating Arms - Grommet or Desk Mount | In Stock | £143.67 |
StarTech.com Monitor Mount - USB Passthrough | In Stock | £176.82 |
StarTech.com Dual Monitor Mount - Stackable | In Stock | £226.92 |
StarTech.com Dual Monitor Stand | In Stock | £91.00 |
StarTech.com DisplayPort to HDMI - 4K 60Hz | In Stock | £23.58 |
StarTech.com Vertical Dual Monitor Stand | In Stock | £90.68 |
StarTech.com Vertical Dual Monitor Mount | In Stock | £76.91 |
StarTech.com 1m USB 3.1 C Cable w/ PD (5A) | In Stock | £26.96 |
StarTech.com Dual 4K Docking Station, Mac & Windows - USB-A & USB-C Dock, Dual 4K60 DP & HDMI | In Stock | £134.82 |
StarTech.com Thin Client Mount - VESA | In Stock | £26.25 |
StarTech.com 1.8m USB 3.1 5Gbps with PD (5A) C to C Cable - M/M Certified | In Stock | £24.40 |
StarTech.com 20" USB C Cable 10Gbps Gen2 | In Stock | £13.40 |
StarTech.com 6ft USB C Cable 5Gbps Gen1 | In Stock | £19.03 |
StarTech.com USB C Dock DP 4K30Hz or VGA | In Stock | £115.87 |
