Two Video Output Options with HDMI or VGA
This USB-C multiport adapter features both an HDMI and VGA port providing you with two single video output options for your boardroom presentations or your workstation setup including support for an ultra-wide monitor. -
Power & Charge with 100W Power Delivery 3.0
With support for USB PD 3.0 (up to 100W), the USB Type-C multiport adapter lets you power and charge your laptop, and power your peripherals when connected to a USB-C power adapter. The USB-C hub features PD passthrough so you can use your laptop's own charger to power the hub (requires 12W) and power or charge your laptop simultaneously. -
All the Essential Ports with USB
The USB-C to USB 3.0 hub gives you one USB-C port (power & data) and two USB-A ports to connect your latest and legacy USB devices; includes a gigabit Ethernet port for a direct LAN connections. -
Enhance Productivity and Device Management with the StarTech.com Connectivity Tools Application
Developed to improve performance and security, StarTech.com Connectivity Tools is the only software suite on the market that works with a wide range of IT connectivity accessories. The software suite includes: •Text | Advanced Windows Layout Utility : To setup and save custom windows layouts. •Text | Mac Address Pass-Through Utility : To improve network security. •Text | USB Event Monitoring Utility : To track and log connected USB devices •Text | Wi-Fi Auto Switch Utility : Enabling users to quickly access faster network speeds via wired LAN.
- StarTech.com USB-C Multiport Adapter, USB-C to 4K 30Hz HDMI or 1080p VGA, USB Type-C Mini Dock with 100W Power Delivery Passthrough, 3-Port USB 3.0 Hub 5Gbps, GbE, 12" Long Attached Cable - Works w/ Thunderbolt 3 (DKT30CHVPD2) - docking station - USB-C - VGA, HDMI - GigE
- Product Type
- Docking station
- Docking Interface
- USB-C
- Video Interfaces
- VGA, HDMI
- 31 cm x 5.2 cm x 1.4 cm
- 110 g
- Grey, black
- Networking
- Gigabit Ethernet
- 3-year warranty
- Product Type
- Docking station
- 31 cm
- 5.2 cm
- 1.4 cm
- 110 g
- Enclosure Colour
- Grey, black
Video
- Max Resolution Details
- 3840 x 2160 - 30 Hz
- Data Link Protocol
- 1 x display / video - VGA - 15 pin HD D-Sub (HD-15) without pin 9 , 1 x display / video - HDMI - 19 pin HDMI Type A , 1 x SuperSpeed USB 3.0 - 9 pin USB Type A , 1 x USB-C - 24 pin USB-C , 1 x network - 10Base-T/100Base-TX/1000Base-T - RJ-45 , 1 x USB 3.1 Gen 1 with Battery Charging 1.2 - 9 pin USB Type A
- Cables Included
- 1 x USB-C cable - integrated - 30 cm
- USB powered, 100W power delivery
- FCC, RoHS, WEEE, USB Battery Charging Specification Rev. 1.2
- OS Required
- Google Chrome OS, Ubuntu 18.04, Android 9.0 (Pie), Apple iPadOS, Apple MacOS X 10.10 - 10.15, Ubuntu 20.04, Apple macOS 11.0, Windows 8.1 / 10 / 11, Apple macOS 12.0, Apple macOS 13.0
- Limited warranty - 3 years
- Shipping Width
- 14.2 cm
- Shipping Depth
- 17 cm
- Shipping Height
- 3 cm
- Shipping Weight
- 135 g
- 0 °C
- 45 °C
