StarTech.com USB-C Multiport Adapter - HDMI
Quicklinx: CX8WWS00 Mfr#: DKT30CHVW
More than 50 in stock
£48.74 ex VAT
£58.48 inc VAT
Turn a laptop into a compact workstation wherever you work or go, adding 4K video, Gigabit Ethernet, and a USB 3.0 port through USB Type-C (5Gbps). Expand the connectivity of your USB-C enabled laptop. This USB-C multiport adapter lets you turn your laptop into a powerful workstation, virtually anywhere you go, eliminating the hassle of carrying and connecting many different port adapters. This 4-in-1 adapter lets you add 4K Ultra HD HDMI or VGA video output, one USB 3.0 Type-A port, and one Gigabit Ethernet port through your laptop's USB-C port.
It's the perfect travel accessory for your MacBook Pro, Chromebook, Dell XPS, or other USB Type-C equipped laptop, giving you the most common video outputs plus other essential added port options. It features a sleek white and silver design that looks great next to your laptop, and it's also Thunderbolt 3 port compatible.
The multiport adapter enhances the connectivity of your port-limited laptop, giving you the ability to connect to multiple devices simultaneously. When coupled with your laptop display, this versatile USB-C multiport adapter makes it easy to create a powerful workstation.
The USB-C multiport adapter provides HDMI (with audio) and VGA ports, so you can easily connect a 4K HDMI or a standard-definition VGA monitor. Connect a high-resolution monitor to deliver engaging presentations in boardrooms, classrooms, and conference rooms. Use an HDMI port-equipped television in a hotel room as an external display when traveling. The option of VGA video output means you can connect easily to legacy VGA projection systems or monitors when you need to.
The Gigabit Ethernet port ensures reliable wired network access, ideal for areas with limited Wi-Fi availability.
This compact multiport adapter is USB-powered, so there's no need to carry a separate power adapter with you. It provides both HDMI and VGA video output, giving you the flexibility to adapt to newer and older boardroom setups as needed. The adapter also features a built-in USB-C cable and gives you network connectivity and a USB Type-A connection for optimum versatility as you travel.
  • Create a powerful workstation with 4K video output
    The multiport adapter enhances the connectivity of your port-limited laptop, giving you the ability to connect to multiple devices simultaneously. When coupled with your laptop display, this versatile USB-C multiport adapter makes it easy to create a powerful workstation. The USB-C multiport adapter provides HDMI (with audio) and VGA ports, so you can easily connect a 4K HDMI or a standard-definition VGA monitor. Connect a high-resolution monitor to deliver engaging presentations in boardrooms, classrooms, and conference rooms. Use an HDMI port equipped television in a hotel room as an external display when traveling. The possibility of VGA video output means, you can connect easily to legacy VGA projection systems or monitors, when you need to.
  • Get reliable network connectivity
  • Designed for easy portability
    This compact multiport adapter is USB-powered, so there's no need to carry a separate power adapter with you. It provides both HDMI and VGA video output, giving you the flexibility to adapt to boardroom setups as needed. The adapter also features a built-in USB-C cable and gives you network connectivity and a USB Type A connection for optimum versatility, as you travel.
StarTech.com USB-C Multiport Adapter - Portable USB Type-C/TB3 Laptop Travel Dock w/ 4K HDMI or VGA - Gigabit Ethernet, USB-A 3.0 - White - external video adapter - white, silver
External video adapter
Bus Type
USB-C
Max Resolution
3840 x 2160
Network (RJ-45) , VGA , HDMI , USB 3.0 , USB-C
5.4 cm x 11.4 cm x 1.7 cm
Enclosure Colour
White, silver
3-year warranty
Bus Type
USB-C
Max Resolution
3840 x 2160
HD/4k Ready, CH7517 chipset
Video Input
USB powered, plastic housing
Google Chrome OS, Apple OS X 10.10 Yosemite or later, Windows 8 / 8.1 / 10
1 x USB-C cable - 10.5 cm
FCC, RoHS, WEEE, RCM
5.4 cm
11.4 cm
1.7 cm
72 g
Enclosure Colour
White, silver
Limited warranty - 3 years
5 °C
35 °C
5 - 95% (non-condensing)
CX8W StarTech.com USB-C Multifunction Adapter 4K In Stock £47.58
CX8W StarTech.com USB-C Multifunction Adapter In Stock £61.41
CX8W StarTech.com USB-C to 4K HDMI Adapter with Power Delivery In Stock £34.93
CX8W StarTech.com USB-C to VGA Adapter with PD In Stock £30.85
CX8W StarTech.com USB-C to 4K HDMI Adapter w/ PD In Stock £32.94
CX8W StarTech.com USB-C Adapter - PD - Silver In Stock £57.52
CX8W StarTech.com USB-C Multiport Adapter - DVI In Stock £48.76
CX8W StarTech.com USB-C Multiport Adapter - HDMI In Stock £48.74
Price Range Ex VAT: 0 - 50
