StarTech.com USB-C Laptop Dock - MST and PD
MUST-HAVE ACCESSORY FOR YOUR USB-C EQUIPPED LAPTOP!
Last Few Remaining
Clearance
Quicklinx: C9WMWS00 Mfr#: MST30C2DPPD
10 in stock
£107.66 ex VAT
£129.19 inc VAT
Power and charge your laptop through USB Type-C (5Gbps), and create an MST based, dual-monitor workstation. Here's a must-have accessory for your USB-C equipped laptop. This dual-monitor docking station is one of the first to integrate the next-generation USB-C host connector, so you can easily power and charge your laptop through its USB Type-C port. And, because it supports MST, you can connect multiple monitors through just one DisplayPort connection.
With power delivery, MST, dual video (DV), or 4K Ultra HD support, this innovative docking station caters to a range of users, such as IT administrators, designers and animators.
USB-C is here. It's the future of universal connectivity, and many new laptops and tablets already feature USB Type-C ports. This versatile laptop dock capitalizes on the full potential of USB Type-C, which simultaneously transfers power, video, and data.
This docking station supports USB Power Delivery (up to a maximum of 60 watts), so you can power and charge your laptop directly through its USB-C port. Because a single power adapter can be used for your dock and laptop, you can reduce clutter at your workstation. Plus, you don't need to carry or remember an extra power adapter when you're traveling to or from the office.
Typical USB Type-A docks restrict video and data to 5Gbps shared bandwidth. This USB Type-C dock allocates data and video traffic separately, so extra bandwidth can be diverted to a particular video or data function, as needed. The USB-C laptop dock offers optimal performance when using multiple monitors and peripherals, so you can get more work done in less time.
This versatile dock gives you two options for connecting dual monitors. With more monitors, you can multitask and increase productivity, by eliminating the hassle of flipping between several open windows.
For dual video, you can easily connect your DisplayPort and HDMI monitors. Alternatively, you can connect multiple monitors to the dock's DisplayPort connection using MST, making it easy to connect multiple DP 1.2 monitors in a daisy chain.
This dual-monitor docking station with MST makes it easier to deploy multiple displays of the same type across organizations, businesses, or hot desks. It can help you save money on volume monitor purchases, and it makes it easier to manage and troubleshoot problems.
The USB-C laptop dock features a DisplayPort and an HDMI port, giving you the flexibility to connect your displays as needed. It supports dual monitors or a single high-resolution 4K monitor.
For extra screen space, this dock offers support for the higher 4096 x 2160p resolution, unlike traditional 4K docking stations that only support 3840 x 2160p.
This full-featured universal docking station offers the ports you need to create a full-sized workstation, including four USB 3.0 ports (including a fast charge-and-sync port and a USB-C port), plus Gigabit Ethernet, audio, and microphone connections.
StarTech.com Dual Monitor USB-C Laptop Docking Station with 4K HDMI, DisplayPort, 4xUSB 3.0 Ports & 60W PD - USB C Dock for Windows (MST30C2DPPD) - docking station
Docking station
Docking Interface
USB
9.1 cm x 21 cm x 2.8 cm
133 g
Australia, North America, United Kingdom, Europe
Gigabit Ethernet
Power adapter 90 Watt AC 120/230 V
3-year warranty
P/N: ARMBARDUO, ARMDUAL, ARMDUAL30, ARMSLIMDUO, TBLT3MM1MA, TBLT3MM2M, TBLT3MM2MA
Docking station
9.1 cm
21 cm
2.8 cm
133 g
Enclosure Colour
IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, USB 1.1, USB 2.0, USB 3.0, USB 3.1
1 x display / video - DisplayPort input - 20 pin DisplayPort , 1 x display / video - HDMI input - 19 pin HDMI Type A , 1 x network - 10Base-T/100Base-TX/1000Base-T - RJ-45 , 2 x SuperSpeed USB 3.0 - input - 9 pin USB Type A , 2 x USB 3.1 - input - 24 pin USB-C , 2 x audio - output - mini-phone 3.5 mm , 1 x SuperSpeed USB 3.0 - output - 9 pin USB Type A
1 x USB-C cable - external
MST (multi-stream transport)
FCC, RoHS, WEEE, RCM, USB Battery Charging Specification Rev. 1.2, USB Power Delivery 2.0, DisplayPort 1.2
Power adapter
AC 120/230 V
Power Provided
90 Watt
Microsoft Windows 7 / 8 / 8.1 / 10 (32/64 bits)
Limited warranty - 3 years
5 °C
35 °C
C9WM StarTech.com Universal USB 3.0 4K Laptop Docking Station w/ 4K DisplayPort In Stock £121.89
C9WM StarTech.com Triple-Video Laptop Dock In Stock £151.46
C9WM StarTech.com Docking Station for 2 Laptops In Stock £158.19
C9WM StarTech.com 4K DP Laptop Docking Station In Stock £100.60
C9WM StarTech.com USB-C Multifunction Adapter 4K In Stock £47.58
C9WM StarTech.com USB-C Laptop Dock - MST and PD In Stock £107.82
C9WM StarTech.com USB-C Multifunction Adapter In Stock £49.05
Price Range Ex VAT: 100 - 150
