StarTech.com USB-C Ethernet Adapter with Extra USB Port - USB 3.1 Type-C
Quicklinx: FK1RWS00 Mfr#: US1GC301AUW
Wired / Wireless: Wired
Protocol: Ethernet, Gigabit Ethernet, Fast Ethernet
Form Factor: External
Type: Network adapter
29 In Stock
£36.73 ex VAT
£44.07 inc VAT
USB-C to Network Adapter 10/100/1000Mbps Thunderbolt 3 Compatible RJ45. This USB-C Ethernet adapter connects you to a Gigabit network through the USB-C or Thunderbolt 3 port on your laptop or desktop computer and adds connectivity for an additional USB (Type-A) peripheral device.  It's a great companion for your MacBook, Chromebook or Windows  laptop with an available USB-C port.
Powerful Gigabit Network Connections
The USB-C network adapter supports full Gigabit bandwidth by harnessing the performance of USB 3.1 Gen 1. You can quickly access very large files over the network at Gigabit speed.
Native Driver Support Makes Installation Easy
Get up and running quickly. Simply plug the adapter into the USB Type-C port on your laptop and connect to your network. The network adapter chipset provides native driver support in Chrome OS , Windows , and macOS.
Trouble-Free Connections Through USB-Type-C
The USB-C connector is smaller and easier to use than previous USB connectors. It's a reversible plug so you can connect to your devices with either side facing up, without frustration or the risk of port damage.
With a compact design, this USB-C network adapter is as portable as your laptop, perfect for ultra-portable devices that have a USB-C port, such as the MacBook and Chromebook Pixel . The network adapter is bus-powered which makes it easy to connect when you're on the go.
Additional Connectivity With an Extra USB 3.1 port
Some computers with USB Type-C only offer one port for external connectivity. This Ethernet adapter features a built-in USB Type-A port, giving you the freedom to attach an additional peripheral device, such as a USB mouse.
The US1GC301AUW is backed by a StarTech.com 2-year warranty and free lifetime technical support.
  • Powerful Gigabit Network Connections
  • Native Driver Support Makes Installation Easy
  • Trouble-Free Connections Through USB-Type-C
    The USB-C connector is smaller and easier to use than previous USB connectors. It's a reversible plug so you can connect to your devices with either side facing up, without frustration or the risk of port damage. With a compact design, this USB-C network adapter is as portable as your laptop, perfect for ultra-portable devices that have a USB-C port, such as the MacBook and Chromebook Pixel . The network adapter is bus-powered which makes it easy to connect when you're on the go.
  • Additional Connectivity With an Extra USB 3.1 port
    Developed to improve performance and security, StarTech.com Connectivity Tools is the only software suite on the market that works with a wide range of IT connectivity accessories. The software suite includes: •Text | Mac Address Pass-Through Utility : To improve network security. •Text | Wi-Fi Auto Switch Utility : Enabling users to quickly access faster network speeds via wired LAN.
StarTech.com USB C to Gigabit Ethernet Adapter with USB A Port, White 1Gbps NIC USB 3.0/USB 3.1 Type C Network Adapter, 1GbE USB-C RJ45/LAN TB3 Compatible Windows MacBook Pro Chromebook - USB C to Ethernet (US1GC301AUW) - network adapter - USB-C - Gigabit Ethernet + USB 3.1 Gen 2
Network adapter
External
Interface (Bus) Type
USB-C
Ports
3.5 cm 1.7 cm
Length
27.5 cm
38 g
Cabling Type
Ethernet 10Base-T, Ethernet 100Base-TX, Ethernet 1000Base-T
10Mb LAN, 100Mb LAN, 1GbE
IEEE 802.3, IEEE 802.3u, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.3az, USB 3.1
White
Microsoft Windows Server 2008 R2, Microsoft Windows 2003, Google Chrome OS, Microsoft Windows Server 2012, Linux Kernel 2.6.25 or later, Apple MacOS X 10.11 - 10.14, Linux LTS versions only, Apple macOS 11.0, Microsoft Windows XP / Vista / 7 / 8 / 8.1 / 10 / 11, Apple macOS 12.0, Apple macOS 13.0
Network adapter
External
USB-C
Ports
Wired
Cabling Type
Full duplex capability, WOL, auto-uplink (auto MDI/MDI-X), USB powered, IPv4 and IPv6 Large Send Offload and Checksum Offload (LSO/TCO), Jumbo Frames support, plastic housing, Energy Efficient Ethernet
1 x 1000Base-T - RJ-45 - female , 1 x USB 3.1 Gen 1 - 9 pin USB Type A - female
USB-C cable (integrated) - 20.3 cm
FCC, RoHS, WEEE, REACH
White
3.5 cm
1.7 cm
Length
27.5 cm
38 g
Shipping Width
14.3 cm
Shipping Depth
17 cm
Shipping Height
3 cm
Shipping Weight
92 g
50 °C
5 - 80%
FK1R StarTech.com USB-C to Gigabit Adapter In Stock £41.49
FK1R StarTech.com USB-C to Ethernet Adapter In Stock £27.31
Protocol: Ethernet
Protocol: Gigabit Ethernet
Protocol: Fast Ethernet
