Maximize your productivity during business travel. This USB-C multiport adapter with HDMI and VGA is like four adapters in one, giving you flexible video output, a USB 3.0 port and Gigabit Ethernet port, a hideaway cable, plus robust power and charging.
With easy plug-and-play installation on most operating systems, the USB-C adapter doesn't require additional drivers or software. It's the perfect accessory for MacBook, Dell XPS, Chromebook or other USB-C laptops.
The USB-C to HDMI and VGA adapter keeps you prepared for business travel. Extend your laptop's display by connecting to a 4K HDMI (4096 x 2160 or 3840 x 2160 resolution) or VGA (1920 x 1200) monitor or projector, to make presentations or set up a workstation.
With support for 95W Power Delivery 3.0 (PD 3.0), the USB Type-C multiport adapter provides up to 85W laptop charging while also powering your peripheral when connected to a USB-C power adapter. PD 3.0 features Fast Role Swap to prevent USB data disruption when you unplug to switch power sources (USB-C power adapter to bus power).
With multiple ports and an easily accessible hideaway cable, the USB-C all-in-one adapter makes an ideal travel dock. Plus, it's bus powered for easy portability.
The USB-C adapter lets you add a flash drive, mouse or other device using the Type-A port. Add wired network connectivity with the GbE port.
Connect a UHD 4K HDMI or VGA Monitor
The USB-C to HDMI and VGA adapter keeps you prepared for business travel. Extend your laptop's display by connecting to a 4K HDMI (4096 x 2160 or 3840 x 2160 resolution) or VGA (1920 x 1200) monitor or projector, to make presentations or set up a workstation. -
Powerful Laptop?Charging
With support for?95W?Power?Delivery?3.0 (PD 3.0),?the?USB Type-C multiport adapter?provides?up to?85W laptop charging while also powering your peripheral?when connected to a USB-C power adapter.?PD?3.0 features Fast Role Swap to prevent USB data disruption when?you?unplug?to?switch?power sources (USB-C power adapter to?bus power). -
Convenient Cable Management
With multiple ports and an easily accessible hideaway cable, the USB-C all-in-one adapter makes an ideal travel dock. Plus, it's bus powered for easy portability. -
Enhance Productivity
The?USB-C adapter?lets you add a flash drive, mouse or other device using the Type-A port. Add wired network connectivity with the GbE port. -
Enhance Productivity and Device Management with the StarTech.com Connectivity Tools Application
Developed to improve performance and security, StarTech.com Connectivity Tools is the only software suite on the market that works with a wide range of IT connectivity accessories. The software suite includes: •Text | Advanced Windows Layout Utility : To setup and save custom windows layouts. •Text | Mac Address Pass-Through Utility : To improve network security. •Text | USB Event Monitoring Utility : To track and log connected USB devices •Text | Wi-Fi Auto Switch Utility : Enabling users to quickly access faster network speeds via wired LAN.
- StarTech.com USB C Multiport Adapter to 4K HDMI or 1080p VGA, USB Type C Travel Dock with 95W PD Pass-Through, USB-A, Gigabit Ethernet, USB-C Video Display Adapter Mini Docking Station - 95W Power Delivery (DKT30CHVGPD) - docking station - USB-C - VGA, HDMI - 1GbE
- Product Type
- Docking station
- Docking Interface
- USB-C
- Video Interfaces
- VGA, HDMI
- Networking
- Gigabit Ethernet
- 3-year warranty
- Product Type
- Docking station
Video
- Max Resolution Details
- 4096 x 2160 (HDMI only) , 1920 x 1080 (VGA only)
- Data Link Protocol
- Gigabit Ethernet
- 1 x USB-C with Power Delivery , 1 x USB-C (power port) , 1 x SuperSpeed USB 3.0 , 1 x network - RJ-45 , 1 x audio / video - HDMI - 19 pin HDMI Type A , 1 x display / video - VGA - 15 pin D-Sub (DB-15)
- Cables Included
- 1 x USB-C cable - integrated
- 4K Ultra HD, 85W power delivery, Fast Role Swap
- Plug and Play, USB Power Delivery 3.0
- OS Required
- Google Chrome OS, Apple MacOS X 10.11 - 10.15, Apple macOS 11.0, Microsoft Windows 7 / 8 / 8.1 / 10 / 11, Apple macOS 12.0, Apple macOS 13.0
- Limited warranty - 3 years , Technical support - lifetime
