StarTech.com USB C Adapter - HDMI & VGA, PD
Quicklinx: DZ4FWS00 Mfr#: DKT30CHVGPD
Maximize your productivity during business travel. This USB-C multiport adapter with HDMI and VGA is like four adapters in one, giving you flexible video output, a USB 3.0 port and Gigabit Ethernet port, a hideaway cable, plus robust power and charging.
With easy plug-and-play installation on most operating systems, the USB-C adapter doesn't require additional drivers or software. It's the perfect accessory for MacBook, Dell XPS, Chromebook or other USB-C laptops.
The USB-C to HDMI and VGA adapter keeps you prepared for business travel. Extend your laptop's display by connecting to a 4K HDMI (4096 x 2160 or 3840 x 2160 resolution) or VGA (1920 x 1200) monitor or projector, to make presentations or set up a workstation.
With support for 95W Power Delivery 3.0 (PD 3.0), the USB Type-C multiport adapter provides up to 85W laptop charging while also powering your peripheral when connected to a USB-C power adapter. PD 3.0 features Fast Role Swap to prevent USB data disruption when you unplug to switch power sources (USB-C power adapter to bus power).
With multiple ports and an easily accessible hideaway cable, the USB-C all-in-one adapter makes an ideal travel dock. Plus, it's bus powered for easy portability.
The USB-C adapter lets you add a flash drive, mouse or other device using the Type-A port. Add wired network connectivity with the GbE port.
  • Connect a UHD 4K HDMI or VGA Monitor
  • Powerful Laptop?Charging
    With support for?95W?Power?Delivery?3.0 (PD 3.0),?the?USB Type-C multiport adapter?provides?up to?85W laptop charging while also powering your peripheral?when connected to a USB-C power adapter.?PD?3.0 features Fast Role Swap to prevent USB data disruption when?you?unplug?to?switch?power sources (USB-C power adapter to?bus power).
  • Convenient Cable Management
  • Enhance Productivity
    The?USB-C adapter?lets you add a flash drive, mouse or other device using the Type-A port. Add wired network connectivity with the GbE port.
    Developed to improve performance and security, StarTech.com Connectivity Tools is the only software suite on the market that works with a wide range of IT connectivity accessories. The software suite includes: •Text | Advanced Windows Layout Utility : To setup and save custom windows layouts. •Text | Mac Address Pass-Through Utility : To improve network security. •Text | USB Event Monitoring Utility : To track and log connected USB devices •Text | Wi-Fi Auto Switch Utility : Enabling users to quickly access faster network speeds via wired LAN.
StarTech.com USB C Multiport Adapter to 4K HDMI or 1080p VGA, USB Type C Travel Dock with 95W PD Pass-Through, USB-A, Gigabit Ethernet, USB-C Video Display Adapter Mini Docking Station - 95W Power Delivery (DKT30CHVGPD) - docking station - USB-C - VGA, HDMI - 1GbE
Docking station
Docking Interface
USB-C
Video Interfaces
VGA, HDMI
Gigabit Ethernet
3-year warranty
Docking station
Video
Max Resolution Details
4096 x 2160 (HDMI only) , 1920 x 1080 (VGA only)
Gigabit Ethernet
1 x USB-C with Power Delivery , 1 x USB-C (power port) , 1 x SuperSpeed USB 3.0 , 1 x network - RJ-45 , 1 x audio / video - HDMI - 19 pin HDMI Type A , 1 x display / video - VGA - 15 pin D-Sub (DB-15)
1 x USB-C cable - integrated
4K Ultra HD, 85W power delivery, Fast Role Swap
Plug and Play, USB Power Delivery 3.0
Google Chrome OS, Apple MacOS X 10.11 - 10.15, Apple macOS 11.0, Microsoft Windows 7 / 8 / 8.1 / 10 / 11, Apple macOS 12.0, Apple macOS 13.0
Limited warranty - 3 years , Technical support - lifetime
DZ4F StarTech.com USB-C Multifunction Adapter In Stock £47.42
DZ4F StarTech.com USB-C to VGA Adapter with PD In Stock £12.05
DZ4F StarTech.com USB-C Multiport Adapter - DVI In Stock £17.11
DZ4F StarTech.com USB-C Adapter with HDMI & VGA In Stock £27.56
