Add high-powered, dual band Wireless-N connectivity, with extended range to a desktop or laptop through USB. The USB300WN2X2D dual-band Wireless-N USB Network Adapter allows a USB-enabled computer to connect to a WiFi network on the 2.4GHz or 5GHz frequency. The adapter can be used for connecting to Wireless-A, B, G or N networks, and features dual 5dBi high gain antennas, as well as powered amplifiers to ensure optimized reception capable of supporting up to 300Mbps of data bandwidth over distances up to 3 times greater than a standard WiFi adapter.
This versatile dual band network adapter features a 2T2R (2 transmitter, 2 receiver), Multiple Input/Multiple Output (MIMO) design, and can connect to older wireless access points (that may only operate on a 2.4GHz frequeny), as well as newer WAPs that support the less congested 5 GHz range.
The USB300WN2X2D is designed to provide a dependable, long-lasting wireless access solution.
- StarTech.com USB 802.11N Dual Band Wireless Network Adapter - 300 Mbps High Power 2T2R Wi-Fi 2.4/5GHz - network adapter - USB 2.0
- Network adapter
- Form Factor
- External
- Interface (Bus) Type
- USB 2.0
- 5.6 cm x 8.8 cm x 1.8 cm
- 35 g
- Data Link Protocol
- 802.11a, 802.11b/g/n
- Data Transfer Rate
- 300 Mbps
- Frequency Band
- 2.4 GHz, 5 GHz
- Processor
- Ralink RT3572L
- IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n
- Black
- System Requirements
- Microsoft Windows Server 2008 R2, Microsoft Windows Vista (32/64 bits), Linux Kernel 2.6.32, Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Microsoft Windows Server 2003 (32/64-bits), Windows 8 (32/64 bits), Windows 10 (32/64 bits)
- 2-year warranty
- Designed For
- P/N: R150WN1X1T
- Network adapter
- Form Factor
- External
- USB 2.0
- Connectivity Technology
- Wireless
- 300 Mbps
- Frequency Band
- 2.4 GHz, 5 GHz
- Status Indicators
- Link/activity
- Wi-Fi Multimedia (WMM) support, Quality of Service (QoS), Wi-Fi Protected Setup (WPS), 2T2R MIMO technology
Aerial
- Antenna
- External detachable
- Antenna Qty
- 2
- Gain Level
- 5 dBi
Processor / Memory
- Processor
- Ralink RT3572L
- Connections
- 1 x USB 2.0 - 5 pin Micro-USB Type B
- Cables Included
- 1 x USB extension cable (external)
- Encryption Algorithm
- AES, 128-bit WEP, 64-bit WEP, TKIP, WPA, WPA2
- FCC, RoHS
- Black
- Software Included
- Drivers & Utilities
- OS Required
- 5.6 cm
- 8.8 cm
- 1.8 cm
- 35 g
- Limited warranty - 2 years
- 0 °C
- 60 °C
- 10 - 90%
- Designed For
- P/N: R150WN1X1T
