StarTech.com USB 3 to HDMI w/ USB Hub
Quicklinx: 8NV9WS00 Mfr#: USB32HDEH
47 in stock
£48.28 ex VAT
£57.93 inc VAT
Connect an HDMI-equipped display through USB 3.0, while keeping the USB 3.0 port available. The USB32HDEH USB 3.0 to HDMI Adapter turns a USB 3.0 port into an HDMI output port with 1920x1200/1080p video support. The adapter features a built-in 1-Port USB 3.0 hub, which offers a connection port in place of the USB port used for connecting the HDMI adapter - an ideal workaround for Ultrabook or laptop users, where only a limited number of USB ports are available.
Functioning as an external graphics card, this USB to HDMI adapter provides a convenient way to add multi-monitor capability to a USB 3.0-enabled desktop or laptop computer (optimal performance from USB 3.0, backward compatible with USB 2.0).
Leveraging the high-bandwidth (5 Gbps) SuperSpeed USB 3.0 interface, the adapter delivers smooth, high-definition content to your HDMI display / projector. The adapter can be used to mirror your primary desktop, showing the same image on each display, or to extend your desktop to double your workspace and increase your productivity. The included HDMI to DVI adapter also allows you to use this device with a DVI display.
StarTech.com USB 3.0 to HDMI External Video Card Adapter w/ 1-Port USB Hub - external video adapter - T5-302 - 16 MB - black
External video adapter
Bus Type
SuperSpeed USB 3.0
Graphics Engine
MCT Trigger 5 T5-302
16 MB DDR2
Max Resolution
1920 x 1200
HDMI , USB 3.0 , DVI-D (Single-Link) - with adapter
4.9 cm x 8.5 cm x 1.7 cm
Enclosure Colour
Bus Type
SuperSpeed USB 3.0
Graphics Engine
Max Resolution
1920 x 1200
USB powered, USB Pass-Through
Size
16 MB
DDR2 SDRAM
Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Windows 8 (32/64 bits)
Min Processor Type
Intel Core i3 2.8 GHz
Min RAM Size
2 GB
1 x SuperSpeed USB cable - 16 cm , 1 x HDMI-DVI adapter
Software Included
Drivers & Utilities
WHQL, FCC, RoHS
4.9 cm
8.5 cm
1.7 cm
75 g
Enclosure Colour
50 °C
0 - 85% (non-condensing)
8NV9 StarTech.com USB 3.0 to HDMI and DVI Dual Monitor External Video Card Adapter In Stock £71.20
8NV9 StarTech.com USB 3 to HDMI w/ USB Hub In Stock £48.28
8NV9 StarTech.com Slim USB 3.0 to HDMI External Video Card Multi Monitor Adapter – 1920x1200 / 1080p In Stock £44.38
8NV9 StarTech.com USB 3.0 to HDMI External Multi Monitor Video Graphics Adapter for Mac & PC In Stock £51.94
8NV9 StarTech.com USB 3.0 to 4K HDMI External Multi Monitor Video Graphics Adapter In Stock £67.48
8NV9 StarTech.com USB 3.0 to Dual HDMI Adapter In Stock £55.84
Price Range Ex VAT: 0 - 50
