Connect an HDMI-equipped display through USB 3.0, while keeping the USB 3.0 port available. The USB32HDEH USB 3.0 to HDMI Adapter turns a USB 3.0 port into an HDMI output port with 1920x1200/1080p video support. The adapter features a built-in 1-Port USB 3.0 hub, which offers a connection port in place of the USB port used for connecting the HDMI adapter - an ideal workaround for Ultrabook or laptop users, where only a limited number of USB ports are available.
Functioning as an external graphics card, this USB to HDMI adapter provides a convenient way to add multi-monitor capability to a USB 3.0-enabled desktop or laptop computer (optimal performance from USB 3.0, backward compatible with USB 2.0).
Leveraging the high-bandwidth (5 Gbps) SuperSpeed USB 3.0 interface, the adapter delivers smooth, high-definition content to your HDMI display / projector. The adapter can be used to mirror your primary desktop, showing the same image on each display, or to extend your desktop to double your workspace and increase your productivity. The included HDMI to DVI adapter also allows you to use this device with a DVI display.
- StarTech.com USB 3.0 to HDMI & DVI Adapter with 1x USB Port - External Video & Graphics Card Adapter - Dual Monitor Hub - Supports Windows (USB32HDEH) - docking station - USB 3.0 - HDMI - TAA Compliant
- Product Type
- Docking station
- Docking Interface
- USB 3.0
- Video Interfaces
- HDMI
- 4.9 cm x 8.5 cm x 1.7 cm
- 66 g
- Black
- TAA Compliant
- 2-year warranty
- Designed For
- P/N: HDDVIMM3, HDMIDVIMM10, HDMIDVIMM6, HDMM10, HDMM12, HDMM15, HDMM1MP, HDMM25, HDMM2M, HDMM2MP, HDMM3, HDMM3MP, HDMM50, HDMM50A, HDMM6, HDPMM50
- Product Type
- Docking station
- 4.9 cm
- 8.5 cm
- 1.7 cm
- 66 g
- Enclosure Colour
- Black
Video
- Max Resolution Details
- 1920 x 1200
- USB 2.0, USB 3.0
- 1 x display / video - HDMI - 19 pin HDMI Type A , 1 x SuperSpeed USB 3.0 - 9 pin USB Type A
- Cables Included
- 1 x USB cable - integrated - 16 cm , 1 x HDMI-DVI adapter - external
- USB powered
- FCC, RoHS
- TAA Compliant
- OS Required
- Microsoft Windows XP / Vista / 7 / 8 / 8.1 / 10 (32/64 bits)
- Limited warranty - 2 years
- Shipping Width
- 14.6 cm
- Shipping Depth
- 21.3 cm
- Shipping Height
- 3.8 cm
- Shipping Weight
- 244 g
- Designed For
